(Topic ID: 80267)
Jurassic Park (DATA EAST) club
By louknees
10 years ago
  • 10,137 posts
  • 577 Pinsiders participating
  • Latest reply 6 hours ago by Garrett
  • Topic is favorited by 238 Pinsiders
59 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 10,137 posts in this topic. You are on page 128 of 203.
#6351 4 years ago
A little more info. When I reinstalled the flippers I noticed that the wires were reversed on the EOS switches on the pics I took before removing them. On the left flipper the blue wire goes to the shorter leaf of the EOS switch and the brown wire goes to the long leaf. The right flipper was opposite, blue to long leaf and brown to short leaf. I resoldered them the same way thinking this must be correct.
Also I notice that I don’t get an LED on the flipper board when I just close the first switch on the right but I do get an LED when the second switch gets closed.
Here’s the flipper in question:
#6353 4 years ago
Quoted from harryhoudini:
Swap flipper switches.
Not clear on what you are meaning here? EOS switches or flipper button switches?
#6354 4 years ago
Quoted from PantherCityPins:
I would assume it is an incomplete circuit to the electronic flipper board...
Did you check for cold solder joints, reseat IDC wires to the connector...
Did you check for continuity of the solid state EOS contacts...
Did you check the continuity from the solid state flipper board IDC connector to the
flipper buttons/EOS switch/Flipper coil...
Did you check for bad fuse.
#6355 4 years ago
Quoted from vec-tor:
#6356 4 years ago
Button switches. Bad contacts could cause intermittent function. Or just replace those and eos, easy enough to do and it's excluded.
#6357 4 years ago
This post is to those of you that have purchased Geteos’s JURASSIC PARK T-REX REPLACEMENT STANDUP BOX.
First, let me say that the box is very nice. I am very pleased. My question concerns installing the flasher and spot lights.
If you have installed your replacement box, may I ask if you would be willing to post a picture of the back side of the box with all lamp connections? I am most likely being an idiot and over looking the obvious, but at the moment I am confused.
Thanks,
Phil
#6358 4 years ago
Problem solved, it was the new EOS switch. I guess it either had some residual material on the contact from manufacturing or the switch didn't have quite enough tension to stay closed at rest. I ohmed out the EOS switch and it was clearly not making contact. I cleaned it and readjusted it and everything is back to normal.
Thanks guys!
#6360 4 years ago
Quoted from BleacherBum:
Thanks,
Phil
Sorry for the delay Phil, normally I can respond pretty quick but I was out today on a day trip for work.
Check your PM for a link to the PDF instructions I just put together for the box install.
In case anyone else is looking for them I put the link into the item description in the store.
#6361 4 years ago
Thanks guys!
Awesome. Now get back to playing some
#6362 4 years ago
I received installation instructions from Greg for his replacement standup box. As I figured I was trying to do something stupid. Now have it installed along with the stun gun mid. Both look and work great. Thanks Greg for making these great mods.
Phil
#6363 4 years ago
Phil
Pics or it didnt happen...
#6364 4 years ago
I have one white dino egg ball left for sale, and can ship today. Please PM if interested.
https://pinside.com/pinball/forum/topic/jurassic-park-club/page/127#post-5040679
#6365 4 years ago
Has anyone found good LED replacements to upgrade the look of the “shoot the T-Rex when lit” lamp and the T-R-E-X indicator lamps on the apron? I’m thinking in these modern times there must be an upgrade to the old “bulb condom” look.
#6366 4 years ago
Quoted from fosaisu:
Dude, where you been? Read back, some one made a whole new 3D printer box for that...
Nothing for the apron though...
#6367 4 years ago
Couple of options from Comet:
Non-ghosting white or clear domed red wedge: https://www.cometpinball.com/product-p/1smd5050ng.htm
Non-ghosting red faceted wedge: https://www.cometpinball.com/product-p/2smd3528-ng.htm
#6368 4 years ago
I just put non ghosting LEDs in there with no condom. Works fine.
#6369 4 years ago
Quoted from Mr_Tantrum:
Faceted with a red bulb condom looks great.
#6370 4 years ago
Yup, any of those bulbs. I did the frosted 2SMD and they look good.
#6371 4 years ago
Some one should make a new apron with the letters TREX backlit....just sayin
#6372 4 years ago
Quoted from Chitownpinball:
How about a new sticker that has clear/red inserts? Then just have to use shorty bulbs without domes to fit under. I can probably get that sticker made pretty easily.
#6373 4 years ago
I just put the red condoms back on over the Frosted Warm White LED's. I like the look of the solid red dome instead of a white dome and whatever color base. The condom cleans up the look of a raw LED bulb.
#6374 4 years ago
This is quite doable if there is actually a market for it. I'd be happy to make them for $10 each. I haven't looked or tried, but is there enough clearance for a non-domed LED? I think even that might project above the apron surface.
#6375 4 years ago
I was thinking something like this. Where the "off" lights are a semi-transparent circle that is lit up by a red LED from behind.
#6376 4 years ago
I can look in a few minutes. If not I am guessing the mech can be modified a bit to sit lower, I don't recall any tight clearances. Or heck, a 3D printed armature with different sockets.
I can do the design and printing to if you don't end up doing it. I'm doing some JJPOTC decals right now and I have the decal in question uninstalled. I can give you a scan if needed.
#6377 4 years ago
Not low enough by default, but two easy solutions. One, flex bayonet bulbs, easy enough. Or replacement sockets if you want to go clean. Should be a really easy swap if someone prints the stickers.
0614191412 (resized).jpg0614191412 (resized).jpg0614191415 (resized).jpg0614191415 (resized).jpg0614191415a (resized).jpg0614191415a (resized).jpg0614191416 (resized).jpg0614191416 (resized).jpg
#6378 4 years ago
Thats nice dude!
You could also laser cut the letters with black over the white lens. Then just remake the sticker with a bigger jp logo and font size without the trex letters. Over booooard, lol. Would be cool though.
#6379 4 years ago
Thats nice dude!
Yeah, that could be cool too. I guess you could change the sticker around since you are remaking it.
#6380 4 years ago
You almost have to do decals for both sides, as you will never completely match the coloring or style.
#6381 4 years ago
Yeah, thought about that... then you can definitely redesign it!
I'll do them in a week or two if no one else does. I am in the middle of doing like 10 for JJPOTC.
#6382 4 years ago
Interested to see how these come out? Could be really cool
#6383 4 years ago
Interesting idea, it'll kind of modernize the apron by doing something like that. Hmm I'm going to have a look at it today to see if I can come up with something too.
#6384 4 years ago
Just tossing around some concept and placement ideas. Want to throw some instruction text on there too. Maybe the fence/electrical stuff.
#6385 4 years ago
Btw, this is what the updated sticker looks like that I had sitting around. I am not sure if this was NOS updated or someone redid it, but it surrounds the lights now.
#6386 4 years ago
Mine looks that way too
15606239872313677508917774616400 (resized).jpg15606239872313677508917774616400 (resized).jpg
#6387 4 years ago
Here is a first stab at something.. I figured I would bring in some movie elements and make it a bit more realistic. Open to ideas.
#6388 4 years ago
Here is one of my ideas.
#6389 4 years ago
Whichever version or all that come to be built, I am a fan of the hidden bulb lighting the decal from below. Just looks more complete Imo.
#6390 4 years ago
Shit, I just realized I could use the new sticker and just put some sort of translucent plastic under the lights. Boom, stock but updated.
#6391 4 years ago
Not a bad idea. You could actually just print 4 red circles on photo paper, cut them out, then adhere to underside of the decal.
Also, there is room enough for more than one design to suit different tastes. I like where you are going with yours.
#6392 4 years ago
Not low enough by default, but two easy solutions. One, flex bayonet bulbs, easy enough. Or replacement sockets if you want to go clean. Should be a really easy swap if someone prints the stickers.[quoted image][quoted image][quoted image][quoted image]
I like the flex idea, maybe I’ll get some time tomorrow or early in the week to actually print and fit the art correctly and test a flex bulb.
#6393 4 years ago
Before I go to too much effort, other than the couple of us, is there any interest in this? For me, having to remember to remove the bottom bulb every time I lift the playfield (I’ve broken one, scratched top of my backbox, etc.) is enough of a reason to figure out a flush mount solution.
#6394 4 years ago
I didn't even know this was an issue.
The flex work/fit fine... it's an easy solution if you want to use the existing sticker, as well. I was going to do clear/semi-opaque inserts with red bulbs behind. That way they are white/clear when not lit. I might replace the holders so I can lower them and use a brighter light (the flex have limited options). One of their quasar bulbs or whatever with like 4 SMD on it could be nice.
I'd probably have to get 100 of each printed if I did it.. that's the place I'm using for the POTC stuff, at least. I am guessing interest is limited, maybe 20 people if that.
I need to find some semi-transparent material anyhow for a window on POTC so the same stuff will probably work for this as well. Now that I found the decal, I might just do that... problem is I only have the left. I don't really want to do just the left, but it might look ok. I guess I could see if there is some other option, like Kinkos or something. The other stickers I am making are for targets so they are heavier duty. The biggest thing would be the die cut so it has the right shape. I don't think I could cut them out to look decent, the rounded corners would get murdered.
#6395 4 years ago
Ah so close. I am missing 2 parts, both arriving from PBL on Monday. In the meantime fixing a few little things, tidying up, re-connecting a few cut wires, etc. Got the Geteos mods installed..might mod them a bit Have a hankering for some flickering flame lights on the gate.
#6397 4 years ago
How much does an led fan like that run? The pro ones we use in arrays at work are like $4000 a piece or more.
#6398 4 years ago
Ah so close. I am missing 2 parts, both arriving from PBL on Monday. In the meantime fixing a few little things, tidying up, re-connecting a few cut wires, etc. Got the geteos mods installed..might mod them a bit Have a hankering for some flickering flame lights on the gate.[quoted image]
I'd like to try to play a game with the flippers in those positions - ha!
#6399 4 years ago
They are pricing their model at $250 but you can buy something similar around $150. Then, you have to figure out video on your own.
#6400 4 years ago
Heh... it was screwing with my brain. I need to climb under and hook those up. I just got the diverter in to place (totally forgot it needed a bushing, couldn't figure out what was going on). I'm repairing my ramp break today and barring those two items tomorrow I should be ready to put it back together!
$ 29.95
$ 99.00
Loop Combo Pinball
arcade-cabinets.com
$ 1.00
$ 89.99
Maine Home Recreation
$ 65.00
G-Money Mods
$ 18.95
7,000
London, ON
$ 18.95
4,500 (Firm)
Ronkonkoma, NY
4,400
Vienna, VA
$ 49.99
$ 100.00
G-Money Mods
$ 259.99
Los Angeles, CA
$ 185.00
Sparky Pinball
$ 50.00
Duke Pinball
Paradise Distribution
Nordic Pinball Supply
$ 29.95
$ 29.95
$ 6,999.00
Classic Game Rooms
This page was printed from https://pinside.com/pinball/forum/topic/jurassic-park-club/page/128 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
