Hey folks, looking for some tips on getting T-Rex to more reliably pickup the ball.
Before T-Rex was eating the ball pretty reliably, but side to side was poor. I had the thing apart, cleaned and regreased the gearbox.. and side to side is pretty decent now. But T-Rex lately has gotten less reliable eating the ball. He tends to go down, teeth the ball and not get a full chomp and fails to grab it.
In test, the switches all activate as I think they should. And if I activate the jaw as soon as bottom switch activates and center switch is active, he eats the ball fine. Bottom switch is set to go off as t-rex is as low as I can make it. The center switch has virtually no adjustment play as the arm and throw is quite short.
In test it's fine... in game play he's inconsistent boot to boot. Sometimes I can see he is just a tad to the right from center like he's overshooting.. and I can reproduce it is harder for him to grab the ball in that position with test mode. But the amount he is different is so slight.. maybe 1/8" of an inch at the saucer. That's the only pattern I've been able to identify. The cam action seems fine.. but it's either slightly not far enough down, or slightly off center and he just teeths the ball.
Suggestions?
Also, does anyone have a map of where the flashing #44 bulbs are in the backbox from factory?
Thx!
