(Topic ID: 80267)
Jurassic Park (DATA EAST) club
By louknees
5 years ago
  • 7,262 posts
  • 423 Pinsiders participating
  • Latest reply 2 hours ago by jorro
  • Topic is favorited by 186 Pinsiders
There have been 1,702 images uploaded to this topic. (View topic image gallery).
56 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 7262 posts in this topic. You are on page 116 of 146.
#5751 9 months ago
Quoted from TommyNYC:
Thanks hope home depot carries them
Marco has them for 22 cents. I need one,too.
#5752 9 months ago
Quoted from HIPPY:
Great im on the site looking to order them not sure which one i need. Any chance you can throw up the link ?
#5753 9 months ago
Is it this one ? https://www.marcospecialties.com/pinball-parts/20-9370-1
#5754 9 months ago
Another trough in the world. I'll need to increase the length of the wires for power (for playfield lifting purposes) but it is up and running. Simple process.
#5755 9 months ago
Quoted from Mr_Tantrum:
Who here has removed their side rails for painting or replacement before? Just wondering how difficult it was on this pin and if there are any tips or tricks I need to know before attempting.
Also, what type of tape/adhesive did you use to replace them?
Anybody?
#5756 9 months ago
Quoted from newovad:
I could watch that thing work all day!
#5757 9 months ago
Hi Mr tantrum,
There is a nut and carriage bolt in front, by lockdown bar and a wood screw in back, under the head. Remove those. Then all that is holding it on is double sided tape. Pretty strong stuff, but I use a thin, somewhere sharp, putty knife and just work it down.
Aircraft stripper will take off powder coating and Rust-Oleum textured black is a quite nice match. The I use 3m Auto trim tape to re attach. Hope this helps
#5758 9 months ago
Quoted from kba78:
Hi Mr tantrum,
Thanks. Sounds just like my Williams Getaway which was very similar. The plan is to paint them in a caution tape pattern (safety yellow and gloss black).
#5759 9 months ago
Went to purchase the EnerGI Maestro but had to sign up to be on a waiting list. PM'd maker, and he said that he just sold the last one and now has to wait for new group of buyers before his next run. Told me it could take up to 3 or 4 months.
So, my plea to all JP owners is if you ever thought about buying one of these then now is the time! Help me get mine faster by signing up on the waiting list.
Selfish motives - of course, but you'll benefit also. Get rid of all the clicking during GI changes and also adjust dimming/flashing to help avoid the seizure inducing flashes that this game can have with LEDs installed.
Learn about it here: https://sites.google.com/site/energimaestro
Sign up on the waiting list here: https://docs.google.com/forms/d/e/1FAIpQLSfnci_UqqFLH8AF7CiGq_aPceyLlusw0XluQEeJnGR-PyJ-qQ/viewform
#5760 9 months ago
Went to install my Opto ball through today and ran into an issue. Seems my mounting hole positions are slightly off. Everything on the ball through looks OEM. No mods or hacks to replacements. Just seems that it's off by half a hole. Just enough to where I can't safely mount the board.
How should I proceed. My first thought is to try and extend the left hole just a tiny bit. Hoping the alignment is good at the front, so by extending the left hole just enough, it will hopefully work. Has anyone else run into this yet?
Also, I took my ball-through completely out. Figured I'd give it a nice cleaning, and the cables disconnect at the Z-connector and makes everything tidy. Just 6 wood screws underneath and two machined nuts under the apron.
#5761 9 months ago
Quoted from woody24:
Also, I took my ball-through completely out. Figured I'd give it a nice cleaning, and the cables disconnect at the Z-connector and makes everything tidy. Just 6 wood screws underneath and two machined nuts under the apron.[quoted image][quoted image]
I had the same problem... I drilled both holes bigger. I just grabbed a bit that was bigger, nothing special. Start just bigger then go up until it fits
#5762 9 months ago
I got an "attempted" delivery notice on Saturday for the opto board. I guarantee the mail carrier never left the truck. It was raining that day and I bet he or she simply didn't want to get wet... I was home all day.
#5763 9 months ago
Duplicate
#5764 9 months ago
Quoted from kcZ:
Did you still use the original screws? That was one concern I had, that the hole would be too big for the screw to hold
#5765 9 months ago
Yes, original screws. Just don't drill the holes larger than the screw heads.
#5766 9 months ago
Extend the hole with drill bit (of coarse smaller size than screw head) - or use a small router bit (or small drill bit, like the size of original hole), and create an oval shape.
As your trough is completely out, this is the perfect time to remove the dimples (if any) at ball parking positions.
#5767 9 months ago
Cabinet Speaker - HELP NEEDED
Hi guys
Can someone please let me know which wire is the positive and which is negative
It looks like my speaker is the original factory speaker and I want to upgrade it.
#5768 9 months ago
Quoted from Whitewater:
Hi guys
It looks like my speaker is the original factory speaker and I want to upgrade it.[quoted image]
Look for CN1 connector at Sound Board, check wire colors:
#5769 9 months ago
I mounted mine using existing holes in board and bracket. However, to line up the holes correctly, I used a higher hole on the right side and a lower hole on the left side. In other words, there was a slight upward from left to right slant to the board when installed, but it didn't matter. I had to manually adjust one or two of the LED pairs spacing (maybe a mm or so), but it still works perfectly mounted this way.
#5770 9 months ago
Hi guys
Was my answer from a month ago not good enough?
https://pinside.com/pinball/forum/topic/jurassic-park-club/page/109#post-4888260
#5771 9 months ago
I received my opto board from Davi today! It looks great. It will be a while before I get to install it. I look forward to ditching the flaky micro-switches.
#5772 9 months ago
Quoted from winteriscoming:
Finally!
Here is a quick installation guide, based on Mr. Tantrum's summary.
1) Tin all of the leads on the opto board (very crucial to do this before you install).
2) Put pin in service mode, eject all 6 balls then turn pin off.
3) De-solder all wires from 6 trough switches.
4) Remove both screws from all switches to remove them (set two aside to use for mounting opto board).
5) Mount opto board with backing in place (3D printed protector that came with the board) using 2 screws taken from removed switches (opto board mounting holes aligned with two of the existing threaded bracket holes). In case of offset between ball trough hole and board hole, increase the diameter of board hole (smaller than screw head).
6) Install your +12V DC power source. If the package contains opto board harness:
Unplug original CN2 female connector from sound board.
Plug original CN2 female to Z connector end on opto harness.
Switch on the pin. Make sure that nothing is connected to CN2 on sound board yet.
For double check, measure the voltage levels (12V, unused, unused, -12V, ground, 5V), and polarity at the end of harness (6 pin IDC or Molex) according to CN2 legend on sound board. The harness has polarity pin - this check is for 200% safety.
When everything is fine, power off. Plug opto harness to CN2 position on sound board.
7) Solder power wire to power pads on board (make sure neutral and positive are correct)
8) Turn power on to insure power is going to opto board (orange LED is on) and turn back off.
9) Solder green/white pairs to appropriate station on the board. You don't need to install diodes.
10) Turn on pin and manually test optos, making slight adjustments where needed then turn off pin.
11) Lower playfield completely, power on. Go to service menu, and check the operation: empty the ball trough few times. Carefully adjust optos, if required.
12) Success. Play a game!
#5773 9 months ago
I just picked up my second JP yesterday. When the ball exits the pop bumpers, after the initial plunge, it often drains straight down the middle. My first JP did this fairly frequently too. I suspect this is why sometimes you see the gate at the entrance to the pop bumpers reversed. My question is: Is there a playfield mod, nudging tip or something you can do to lessen how often this happens?
I know you get a ball save, but this is not very satisfying when the second plunge goes straight back into the pop bumpers too.
#5774 9 months ago
Quoted from 7oxford:
Pops are intended to be random and dangerous, so be ready to nudge. That being said, mine don't often do that. Is your pin level?
#5775 9 months ago
OMG how embarrassing , thank you and yes your answer was and is still spot on
#5776 9 months ago
Quoted from Neal_W:
Is your pin level?
Thanks for the tip. Haven’t tested the level yet as I still need to move it from the garage to the games room. Seems to play true enough though.
#5777 9 months ago
Mine literally never does this (at least I've never seen it in the month or two I've owned the pin). I'm at around 6.5 degrees of pitch and perfectly left-right level.
#5778 9 months ago
No worries, just giving you a hard time.
#5779 9 months ago
Quoted from Davi:
…"based on Mr. Tantrum's summary."
I'm honored.
#5780 9 months ago
I have the same sort of issue with mine - however it didn't go into the pop-bumpers, it hit the green post just north of the pop-bumper entry gate (and has created a wear-down-spot there).
I re-leveled the game from left to right and then inclined the game a bit and now it seems to either go into the pop-bumper area or loose momentum, hit the t-gate and roll back towards the flippers.
I shouldn't remove the t-gate correct? anything else I should be trying?
#5781 9 months ago
Quoted from Davi:
Finally!
davi -- thanks for the opt board and the instructions - question though regarding using this board with the CN2 hardness from the soundboard....
I've installed a Pinsound+, along with the pinsound Data East power booster Splitter -- should I be worried about adding an additional item to this power source? is there a particular order in which this additional harness should be installed? The power booster is currently installed between CN4 on the sound board and CN2 on the pinsound board.
#5782 9 months ago
Quoted from JohnJN:
You can't use the opto harness the way I've designed. The Date East power booster replaces the 12V to 18V to avoid sound cut, and use only 5V from original CN2 connector. So in your case, you need 18V and 5V for Pinsound, and 12V for opto board. After some research and drawings, here is my suggestion.
Power off.
1. Unplug 6 way power booster Molex from sound board.
2. Remove original CN2 IDC from power booster harness (Z connector end).
3. Plug original CN2 to opto board harness (Z connector end).
4. Plug 6 way opto board connector to power booster Z connector.
Power on.
4. Now you have to read following voltages:
DE power booster: 18V (blue), unused, unused, unused, ground (black), 5V (red). Make sure that red connector gets 5V, otherwise you can damage the soundboard!
Opto harness: 12V, unused, unused, -12V, ground, 5V.
If every value is OK, plug power booster back to Pinsound.
Maybe with drawing my explanation is more clear, and I hope there is 100% compatibility between connectors.
#5783 9 months ago
Quoted from Davi:
Power off.
Power on.
Maybe with drawing my explanation is more clear, and I hope there is 100% compatibility between connectors.[quoted image]
Thank you Davi -- I don't currently have anything that will read the voltages from the connectors, so I will need to purchase something to triple check your numbers and then try it out.
#5784 9 months ago
Quoted from JohnJN:
No need to spend a ton on a multi-meter. Probably can pick something up at Walmart, Ace, Lowes, Home Depot, etc. Even better if you have a Harbor Freight close by (they have one for $6 - https://www.harborfreight.com/7-function-digital-multimeter-63604.html).
Here are some examples on Amazon for around $10 or less.
amazon.com link »
amazon.com link »
amazon.com link »
amazon.com link »
#5785 9 months ago
amazon.com link »
amazon.com link »
amazon.com link »
amazon.com link »
Thank's mr_tantrum
#5786 9 months ago
Quoted from JohnJN:
Buy one with audible continuity function, this is very useful function to find shorts or check continuity.
#5787 9 months ago
I had to move the pin again and so did a check on the levels today. They are out quite a bit left to right. Will move it into the games room on the weekend and set up all the levels. Hopefully no issues after this.
Quoted from JohnJN:
If you ball is losing momentum, perhaps check the plunger to see if it is shooting the ball straight. You can take a slow motion video with your phone. If the plunger is not firing straight the ball will hit the side wall before the bend and lose speed.
#5788 9 months ago
Quoted from Davi:
Thanks davi
7oxford - Thanks, I will check it -- is there a way to make sure its firing straight...?
#5789 9 months ago
I recently purchased a JP and noticed that it is quite difficult to get the ball up the ramp. I feel as if I have to “power” the ball when hitting the ball with the flipper. When I do get the ball up the ramp, it is normally only with the left flipper (the lower and upper right flipper can’t successfully shoot the ball up the ramp). When I watched YouTube videos of others playing their game, it seems like they don’t have as much trouble as me.
Has anyone else experienced this? If so any ideas how to fix it?
#5790 9 months ago
Quoted from jugood20:
Have you rebuilt your flippers recently? That will help a lot with the power of the flipper. After rebuilding mine, they were almost too strong. Other thing to check is the hanging switch at the front of the ramp. Make sure it can swing freely and isn't getting hung up on just feels tight.
#5791 9 months ago
Mine is similar. Probably 10% of the time the ball exits the pops SDTM. I figured that’s why there’s a ball save!
#5792 9 months ago
Put a white rubber on the post at the bottom pop, white bounces more than black.
Mine sdtm's about 5%
#5793 9 months ago
Since I've got the machine opened up to install the Opto ball through, I bit the bullet and ordered a ColorDMD. Not really wanting to spend $400, I decided I could bring a peanut butter sandwich to work for the next 6 months. ha.
#5794 9 months ago
Oddly enough those two things are installed in completely different places. Sounds to me like you just needed some self-justification (or maybe spousal justification) to buy a ColorDMD.
#5795 9 months ago
Do it for a year and get the pinsound too, it goes in the same area as colordmd
#5796 9 months ago
Quoted from J-Freeze:
Beat me to it, except I would always do PinSound first.
#5797 9 months ago
Had to pull the machine out from the wall, which meant moving some other stuff around the room to get into the backbox to install the power connector to power the opto board.
And Pinsound, I'm just not sold on it. I want 100% original sounds. Now if someone can do a 1 to 1 conversion using high res sounds, then I'd be all over that, but since that hasn't been done, I'm holding off.
Now you may say that the new one sounds a lot better. Sure, it may. To you. But this is my 1994 childhood I'm remembering. Now, if I wasn't as much of a fan of JP as I am, then yeah, I'd probably get it. Heck, if I had any other machine and someone updated the sounds and callouts, I'd probably get it for that too because I'd have a less sentimental attachment to it.
#5798 9 months ago
Damn, I take a PB&J to work most days and still can't afford the ColorDMD
#5799 9 months ago
Quoted from Bugsy:
Reminds me of a story The TODAY show did a few years back "Ways to save money."
1. Don't smoke. I don't.
2. Dont get your latte every day. I don't
3. Keep proper air in the tires to not waste gas. I do.
4. Take out all extra weight in the car to save gas. Already done.
None of them helped me save at all. Its for those who are already wasteful. For me though. I eat out way too much for lunch. Its just not fun staying in to eat.
#5800 9 months ago
You can't have everything! Where would you put it?
Keep on stimulating the local economy.
$ 29.95
$ 399.95
Pin Stadium Pinball LEDs
$ 150.00
3,600
The Colony, TX
$ 259.95
$ 48.00
