Quoted from edward472:Did you notice that your spitter targets and triceratops target aren't 3D targets? Not bashing your machine. It's gorgeous. Just saw it and it made my OCD twitch.
Yes, actually owner was in process of switching out to the flat targets since a few of the originals were broken. He gave me the remainder of the new targets to install, so that is on my to-do list. Will end up with all flats. Might still cause you stress since not the same as original, but at least they will be consistent.
He also liked a little more upward flipper position than I'm typically comfortable with. I need to research what is "standard/default" for this pin regarding flipper position as I think I would like to set to that and then customize to my liking from there if needed.
For the most part I'm happy with the lighting (I've changed a couple of bulbs already), but think I'm going to see if I like white better in some of the GI where green is currently.
I also have one broken plastic (the one attached to the right pop/jet) as it is missing the lower finger that covers the metal bracket. Need to see if anyone has one to sell, or if anyone can at least provide a high res scan so I can make my own.
While the machine is in great condition, I can't help but put a few of my own touches on it. All in due time.
