(Topic ID: 157949)
Jurassic park burning up leds
By PinballHog
8 years ago
#1 8 years ago
I've had several LED bulbs start to smoke and burn out. They don't burn out in test mode. They are burning out in game play. I used all non ghosting led's under the playfield and reg led's for all the gi lighting. I know on one of the non ghosting bulbs that keeps getting to hot that if I put a ghosting led in it it will not burn up. I'm using some of Pinball Life's & Comet led's. I'm wondering if JP you can't use the non ghosting bulbs? Also I checked if all the bulbs that are burning out are in the same column or row and they aren't they are all over the Matrix. A lot of the led's I'm using are Pinball Life's older flat top non ghosting led's but I'm also mixing in some of the newer ones Terry sells the non ghosting with the dome top and some of the comet non ghosting with the dome top which look just like the Pinball Life bulbs. Do you have any ideas for me to check? By the way the game had just old iridescent bulbs in it before I started working on it. They weren't burning out like this. Any info would be greatly appreciated.
#2 8 years ago
Buy the way I just leded the machine tonight, and no gi ghosting bulbs are burning out just the bulbs in the Matrix and all of them are non ghosting.
#4 8 years ago
Did you check the voltage on the sockets where you are having problems?
#5 8 years ago
What should it be like 6 V?
#6 8 years ago
Quoted from PinballHog:
Yes. Flashers are more, though.
#7 8 years ago
On testing the bulbs, I know on gi lighting you set your meter to AC and then touch each post to get your 6v reading. On the lights in the matrix do you keep your meter on AC or DC and ground to the ground strip in the cabinet and touch the red to either of the post on the light socket? Should I test it when the light is lit or off? Should both post read 6v? Let me know if this is right or wrong. Thanks for your help.
#8 8 years ago
http://www.pinwiki.com/wiki/index.php?title=Data_East/Sega
Be sure and learn the basics. Testing a playfield light bulb socket is a DC setting, one pin will have voltage the other will not.
#9 8 years ago
Any chance you have bad / stuck on column drivers? The lamps that are burning out, do they seem extra bright? Are they associated to a single lamp column, or row for that matter?
#10 8 years ago
I have all non ghosting in my LW3 and LAH, never had this issue once, or in Williams, Stern, Sega.. I know they say you don't need non ghosting for GI, but I do them anyway..
#11 8 years ago
I have Comet's of both types throughout my JP with no issues. Check your wiring, as that shaker creates all kinds of chaos on 20yr old solder joints.
#12 8 years ago
Got it fixed guys. It was a transitor that was out. Games working great. Thanks for all the help and advise.
#13 8 years ago
LEDs no likey +18v
#14 8 years ago
If you posted how you figured that out and which transistor it was the next person having issues might benefit from your experience.
Feed T-Rex!
#15 8 years ago
What I did was unplugged both plugs that controls the lights in the matrix. I took a lamp socket with an old bulb and I jumped it to the pins. I started with pin 1 connected to pin 1 then I moved to pin 1 connected to pin 2 then pin 3 and all the way down to 8. Then I went to pin 2 connected to pin 1, 2, 3, all the way to 8. Then pin 3 to pin 1, 2, 3 all the way to 8. I went through all 8 x 8 matrix. Every time I would get to pin 4 (yellow/black wire) the bulb would be extra bright. So I knew there was somthing wrong with somthing in that 4th column. I then took the board off and started testing with my meter the transistors first. When I got to the 4th one up from the bottom, which was the one that was in line with the 4th pin (the bad pin) the transistor tested bad. I replaced it and boom it was fixed. Hope this helps someone else that might have this problem. Thanks again for all the help from you guys and of coarse Lloyd who has also been there to help.
#16 8 years ago
Very clever
#17 8 years ago
Great troubleshooting...
Mitchell Lighting
$ 15.95
$ 1.25
Mitchell Lighting
Nordic Pinball Supply
$ 50.00
Duke Pinball
$ 29.95
$ 49.99
FlipMods
$ 1.00
4,500 (Firm)
Ronkonkoma, NY
Sparky Pinball
$ 285.99
PinSound
$ 185.00
Sparky Pinball
7,000
London, ON
$ 27.95
$ 18.95
$ 259.99
$ 6,999.00
Classic Game Rooms
$ 29.95
$ 99.00
Loop Combo Pinball
Los Angeles, CA
arcade-cabinets.com
This page was printed from https://pinside.com/pinball/forum/topic/jurassic-park-burning-up-leds and we tried optimising it for printing. Some page elements may have been deliberately hidden.
