(Topic ID: 217665)
Junk yard - test report problem on all switches
By jimy_speedt
1 year ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by jimy_speedt
#1 1 year ago
Hi,
This error test report for switches usually happens whn there is a problem with a switch or if the switch was not closed for a while. In my case they are all ok, but the test report requires me toclose them all one by one manually.
Is there any way to mark all switches ok at one time ? Withput going behind or under the playfield for closing them ? Playing a normal game does not make the switch error message disappear, even if the switch is closed during the game.
Thank you
#2 1 year ago
Interesting,
I have the same problem with a Stern Simpsons.
Every time I turn it on tells me to go to diagnostics/check switch's, and ends up being all switch's,
but playing game they all work and test ok?
#3 1 year ago
Hi,
Yes, no issues just boring to get this at machine start
#4 1 year ago
Do a factory reset.
#5 1 year ago
Quoted from jimy_speedt:
It should clear a switch in game play. You have something else going on if it doesn't.
#6 1 year ago
There was definetly an issue with that, at one moment after a game, it disappeared. I did not make a factory reset. I it happens again, I will do. Thank you all for the support.
$ 89.99
$ 79.95
