(Topic ID: 197446)
Junk Yard Sound issue-it would say I'm an idiot, if it could
By Stripes
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by Buzz
#1 4 years ago
Somehow, after installing new, updated sound roms, I installed S2 backwards. Yes, I'm an idiot. I orientated the chip and dropped it and picked it back up reversed. On startup, no sound and I unplugged the machine after about 10 seconds. The S2 was very hot, I assume I fried it. I replaced the updated sound chips I likely just fried with the prior working originals. Now I have no sound and a sound board interface issue error and no led light lit on the AV board. Fuses are good. Suggestions as what to repair? Any chance that S2 is still good? Would it fry all of the sound chips? The game has no other errors or play issues but plays soundless. I found no open fuses on any boards.
I reseated the cables, double checked to ensure the OEM sound roms had all their legs in and were in the proper slot and order.
I know I'm being punished by the pinball gods for updating sound chips that I likely couldn't tell the difference with the new ones anyway. But i couldn't help myself. Now I need help. The AV board shows no signs of burns or charring. Anyone else made this mistake?
#2 4 years ago
Yes I have. Did you put the old one in the right way by chance. Sorry not to be more helpful. Try either one put in the right way and try to see if it boots
#3 4 years ago
Yes, I pulled the plug and grabbed the rom only to find it very hot. I removed it, cooled it down, and put it in correctly, and have no sound. So I removed all 4 sound roms, replaced them with the prior working ones, and I have the error "sound board interface error".
#4 4 years ago
Can anyone tell me what gets fried if you put S2 sound rom in backwards? I notice R44 on the board is very warm while others are not. Thats a 1.8 ohm 5 watt vertical resister. Should it be hot to the touch?
The LED 501 is not lit on the audio visual board, what do I test to troubleshoot it?
#5 4 years ago
Quoted from Stripes:
Does the LED flash at all? It shouldn't be lit constantly, more like a slow flash.
#6 4 years ago
Ok, the Junk Yard is all repaired and working now. After I installed the original sound roms back in the AV board, I failed once again to notice all of the bottom legs on one chip were outside the socket. I know, geez. I'm having my glasses checked, I must need a new script for them.
Thanks to all who tried to help me with this. It was really appreciated. Hopefully this post will help another one day and I sure am glad I didn't have to pony up for the $2995 for a AV board!!
#7 4 years ago
Wow $2995? I had no idea they run that much. Even happier of an ending to turn out to be so simple and not an expensive lesson!
Always take your time and be careful, one chip at a time!
And thanks again for being patient while we could track down some help!
#8 4 years ago
Right on man. Thanks for the update and glad you are playing again. These threads really do help others.
Arcade Upkeep
$ 99.00
Arcade Upkeep
$ 29.95
PinSound
$ 125.00
Blackwood, NJ
Gweem's Mods
$ 54.99
KAHR.US Circuits
