It appears to be stuck in game over. I've done most if not all minor cleaning (jones plugs, checked all wire connections). The switch contacts look like a few are burnt and some are completely silver, but most of them are charcoal colored. This is what happens:
Power On:
-Playfield lights up
-Game Over, Tilt, Player 1 light up
-Q and U Relays are the only ones that pull
+ Both relays keep pulling, buzz, and get warm
+ I replaced both burned coils (no change)
* I press the START relay, the game resets, GameOver and Tilt light up. I press START and HOLD relay, the game resets, GameOver, Player1, and Ball1 light up. The HOLD relay doesn't pull or hold. Ball Roll Tilt switch is closed, the Anti-Cheat switch is open.
(I read the "anti-cheat" switch is on the back of the coin door? please correct me if I'm wrong thanks)
With the Anti-Cheat switch closed, the following happens:
Power On:
-Game Over lights up, Tilt blinks
-Score motor keeps turning
-W, H, T, Bx, Ax Relays keep "pull" clicking
* I press the replay button, the game takes 4 credits, resets, then resets the credits to max, score motor keeps turning and relays keep clicking with game over and tilt lit.
I'm not sure if the switches are in the wrong place or not. I attached a picture I drew of all the switches that look like they were messed with.
Black Line = Off (up) Blue Line = On (down)
Contacts touching are colored in.
Thank you for reading and I hope we can figure it out!
