(Topic ID: 331725)
Jungle Queen
By B-low99
1 year ago
  • 11 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by B-low99
#1 1 year ago
EM noobie here. I need to replace some bulbs on my Gottlieb Jungle Queen back glass. Does the whole unit come out (with scoring reels) I can drop it down a little to see the bulbs but not sure if it comes all the way out. I don't want to smash anything. thanks
#2 1 year ago
You don't need to remove the board everything is mounted on. Just hinge down and replace the bulbs. You can use an old shooter rod rubber tip to pull the old bulbs out if you can't grab them with your fingers.
#3 1 year ago
Be careful tilting the board back. Watch clearance to make sure the disk on the player unit does not hit the cabinet when the board is tilted back.
#4 1 year ago
And it's a good idea to manually actuate the player unit in the backbox. You want it positioned horizontally, so that it doesn't get damaged when you lean the panel backward. My first Gottlieb confused me because my other EMs had the backglass lift out from the front.
EDIT: Bubba beat me by a couple seconds, lol.
#5 1 year ago
Quoted from schudel5:
Don't " pull them out". You have to push down on the bulb and turn to the left to remove. Just the opposite to install.
#6 1 year ago
Quoted from Budman:
I was hoping he knew how to remove bayonet #44/47 lamps, but probably should have worded it differently.
#7 1 year ago
We should also mention to find someone with skinny fingers. Some of those drilled holes in the board tear up my fat fingers!
#8 1 year ago
Quoted from Budman:
I use a piece of plastic tubing for those hard ones. Shooter tip works good too.
#9 1 year ago
Thanks... i do know how!. thanks for the help
#10 1 year ago
Quoted from RC_like_the_cola:
thanks! nice tip
#11 1 year ago
yeah i was worried about that. thanks for the tip!
Lighting
Space Coast Pinball
$ 130.00
Beehive Pinball Co.
