Thanks Dirt,
I'm looking over that thread but admit that much of it is over my head.
I'm making some notes but I'm hoping I triggered a common issue and if anyone can provide:
- Sounds like this switch is stuck, it's located about here, check that one
- If that doesn't work, check this one...
Kind of simplistic yes, but it WAS working fine, I didn't jostle it too badly in transit, and it is lighting up and resetting (reset sounds longer than normal, but does eventually stop), but shows Game over. Flippers and scoring is dead, though you can trip the extra ball or tilt it. I'm thinking it's a simple tweak to right again, I'm just not sure what that tweak is.
Again, no actual work was performed on the machine, the backbox was removed, moved from point A to B, and then reconnected.
I'm heading back there Friday most likely and hope to have a list of things in hand to test/try.
Ideas? Thanks.
