Hello Pinside!
Had my Jungle Princess fully functional, sold it to another pinsider, worked 100% for three days then started to show some issues.
I think these issues are related. Any help is appreciated.
- Upon end of ball or ball drain. The following is noticed; Extra Ball if awarded does not clear, drop targets do not reset, and player ball does not advance.
- Score is added and bonus unit adding the correct amount.
- When ball is drained it does kick out into the shooter lane as expected. Sounds like it is attempting to move the player as the ball indication light blinks.
- Same results are noticed in 3 ball or 5 ball mode.
What has been done recently.
• I just finished fixing the AX relay. During the move it must have come unaligned and was not reseting.
• Cleaned and inspected most other relays.
• Player unit works, coil is good and tested with a MM. Manually advances perfectly.
Otherwise the machine plays and scores great.
DID IT EVER WORK IN YOUR POSSESSION? Yes
WHAT WAS THE LAST SERVICE YOU PERFORMED? Cleaning/Inspecting the Relays
BLOWN FUSES: The main 5Amp SlowBlo was suspect, but not blown so it was replaced. ALL other fuses are good.
SMELL: None
OBVIOUS PAST WORK PERFORMED: Coin door. There was a unused coil hanging from the coin door. Disconnected and removed. Not sure what it was for.
DO YOU HAVE A VOLT METER: yep!~
CAN YOU SOLDER? Totally!
DO YOU HAVE THE SCHEMATIC? Yep!
