Hello I have a jungle lord game that neither slingshot will work on. Where do I start on this. Thanks
Quoted from LTG:Should be tests in there for switches or coils. First figure which isn't working.
Switch test won't help. The slings are special solenoids, so the sling switches won't register in switch test directly. There are secondary switches under the playfield that close when each arm kicks, those are the ones that will register in switch test, but only once it fires.
Main thing that's important here is whether the slings fire in coil test. That will determine what side of the problem to look at
Quoted from zacaj:Switch test won't help. The slings are special solenoids, so the sling switches won't register in switch test directly. There are secondary switches under the playfield that close when each arm kicks, those are the ones that will register in switch test, but only once it fires.
Thank you, I wasn't sure on that.
This page was printed from https://pinside.com/pinball/forum/topic/jungle-lord-slingshots- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
