2503 2
Game is stock.
As last thing i wanna try. Can someone please uploade pics of how coindoor switch is wired/whitch colours. My switch is without any cabels on
2503 2
Game is stock.
Quoted from vec-tor:Game on and in audit mode. Good! If you have batteries and turn
the game on it should go to the game over mode. Or on and off
then on real qwick. ( as not to lose power).
note:2502____1 : *502__rev1 is cosmic gun fight?
Junge Lord is *503
Yes i have boards from cosmic gunfight. There roms dident help, just another "code"
5101ic did not help eather
high score reset
_ *
_
_
GRN-BRN bottom lug left
WHT-GRY bottom lug right (diode anode)
diode cathode (band) middle lug left
_
_________________up/down
__________________ *_
__________________
__________________
BLU top lug left
WHT middle lug left (with yellow jumper)
_
_____________________________advance
_____________________________ *_
jump(yellow) middle lug left
GRN bottom lug left
GRN-BRN (common) right coin, center coin, left coin, slam tilt
__________________ inside top lug"" "" ""
___________________ diode cathode to middle botom lug "" "" ""
_________________WHT-YEL, WHT-GRN, WHT-BLU, WHT-VIO top out side lug anode
Oh tjanks. All buttons work fine. I was after a picture of wires to the switch at coindoor. Look at my earlier pics
Quoted from DEN:Oh tjanks. All buttons work fine. I was after a picture of wires to the switch at coindoor. Look at my earlier pics
That switch is the ram interlock. Black to the Black wire with
the nylon tube and white is soldered to the lug at the bottom.
When the coin door is closed part of the ram cannot be erased.
P.S. they got the wires tied together so it makes it
hard to do adjustments. This could be part of your
problem.
P.S. the white switch assembly could be bad. I would
OHM it out to check for continuity. You might have
to spray some Windex or a little lite oil into the
assembly and exercise the push lever in order
for it to start making contact. That is the only reason
I could think of as to why somebody would cut
and remove those wires. Or, they were just plain
crazy.
Okey. Solderd and did not work.
BUT. Took mpu and driverboard from cosmic gunfight and put all 4 roms in from my JL and now i am playing the game. Its awesome. But no spund though. Will chect that later.
Okey. This means. Voltage all good. All 4 roms all good. My problem is strickley on my mpu+driverboard
This page was printed from https://pinside.com/pinball/forum/topic/jungle-lord-help/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
