Jungle Lord is giving unlimited balls even after reset by power switch. Does anyone know what it possible could be? The ball # does keep counting up.
So the game is starting normally (goes into attract mode, then you hit the start button, then it kicks the ball out and you can score), but it instantly ends the ball, and gets stuck in this cycle? I would check the ball drain switch (far left of the ball trough, where you loose the ball during gameplay). Sounds like it's either misadjusted or the diode has gone bad on it
Quoted from Knxwledge:So the game is starting normally (goes into attract mode, then you hit the start button, then it kicks the ball out and you can score), but it instantly ends the ball, and gets stuck in this cycle? I would check the ball drain switch (far left of the ball trough, where you loose the ball during gameplay). Sounds like it's either misadjusted or the diode has gone bad on it
Thank you for the advise.
Quoted from Femund:The ball # does keep counting up.
Since the ball count is increasing after every drain, the ball drain switch is probably fine.
The sram contents could have been scrambled due to static electricity.
Double check what the value of game adjustments number 30 is currently set to.
To check the adjustments, follow the procedure in the attached .pdf starting on page 8.
If setting 30 is currently set to some high value, change it to either 3 or 5.
fpmanual.pdfWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/jungle-lord-giving-unlimited-balls and we tried optimising it for printing. Some page elements may have been deliberately hidden.
