(Topic ID: 260965)
Jumping Jacks
By Doomer
1 year ago
  • 11 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Doomer
#1 1 year ago
E-Delay Relay on my JJ stays energized on start up and drop target coils fire constantly even thought they are all reset (up position). Score motor rotates constantly. What is causing that coil to stay energized?
Doomer
#2 1 year ago
We're talking about the F/"E" Relay Delay relay, right? That would cause your Score Motor to run and drop targets to reset via the O/Outhole relay which is probably also stuck on.
Start by checking that the two switches in the red box are actually opening. They both need to open to let the F relay relax.
/Mark
#3 1 year ago
Mark,
Thanks for that. will check that today.
Frank
3 weeks later
#4 1 year ago
Well with help from Dave M. My JJ lives again. Still has some issues but nothing major I don't think. Looking for a copy of the instruction card.
10,000 unit is getting a extra pulse which turns the score reel on player one to 1...Any thoughts
#5 1 year ago
Pinball Rebel has the Score/Instruction cards:
http://www.pinballrebel.com/pinball/cards/Gottlieb.htm
#6 1 year ago
Thanks for the post. Printed the instruction card
#7 1 year ago
Need to rebuild my JJ pop bumpers need skirts and caps. Steve Young doesn't seem to have them listed. Any suggestions?
#8 1 year ago
Look again, Steve has everything you need.
#9 1 year ago
caps: '100 Points' In Blue or Red A-11425
skirts: looks like Blue 6 hole?
#10 1 year ago
Ok will check again. Thanks
#11 1 year ago
So almost done with JJ. Player up unit sticky. Does not switch to player two or back to player one unless I do it manually. Not sure I want to attempt a complete disassemble. May just try and lube the pivot points. Any suggestions or pointers. Still getting that extra pulse on start on player one that turns the 10M reel to one?
