So finally broke a target on my JJ. Any hints on the easiest way to replace them all? Should I replace the springs with new ones?
PR has a set for $40. Going to order them.
If you're replacing the targets, definitely replace the springs too. Can't hurt, and never a better time. I had much less issues with mine after replacing the springs
When I broke a target on a JJ, I used Clay's method of mod' ing the target frames using a dremel and cutting wheel. Worked pretty well and the job was done in less than an hour for replacing all targets.
Others might prefer to take apart the mechanisms.
I do the Dremel cutting wheel technique....works well for me. And any future replacements are a breeze.
This page was printed from https://pinside.com/pinball/forum/topic/jumping-jack-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
