Special price on Edge-lit back panel upgrades PLUS $25 flat-rate domestic shipping for Jumbo displays until Monday September 2nd. We enough acrylic for about 10 Edge-lit frames so this offer is while supplies last.
- Clear RGB Edge-lit back panel upgrade - $25 (regular $75).
- Clear RGB Edge-lit back panel upgrade with ~39"x5" custom laser etched message. - $100 (regular $175)
Options available (see photos and videos below)
- Jumbo Red Run-DMD display with standard frame (~39"x11"x2") - $375 shipped
- Jumbo Red Run-DMD display with Edge-lit frame (~39"x11"x2") - $400 shipped
- Jumbo Red Run-DMD display with Edge-lit frame with custom message (~39"x16"x2") - $475 shipped
- Jumbo RGB Run-DMD display with standard frame (~39"x11"x2") - $475 shipped
- Jumbo RGB Run-DMD display with Edge-lit frame (~39"x11"x2") - $500 shipped
- Jumbo RGB Run-DMD display with Edge-lit frame with custom message (~39"x16"x2") - $575 shipped
*** Jumbo RGB Run-DMD display supplies are limited ***
Order through the gameroommods pinside shop!
https://pinside.com/pinball/market/shops/1167-gameroom-mods/02390-jumbo-red-run-dmd-led-display-clock
https://pinside.com/pinball/market/shops/1167-gameroom-mods/02382-jumbo-rgb-run-dmd-led-display-clock
https://pinside.com/pinball/market/shops/1167-gameroom-mods/02128-pinball-dmd-run-dmd-acrylic-frame-kit
Edge-lit frame (~39"x11"x2") upgrades
- Clear back panel replaces standard dark tint back panel
- Display has integrated LED controller with RGB LED strip, edge mount, and switch
- Change the LED colors and modes via the button on the controller.
Edge-lit frame with custom message (~39"x16"x2") upgrades
- Approximate message area is ~39"x5"
- Your message laser-etched into clear acrylic. Pick your message, font, spacing, graphics etc.
- A proof will be provided prior to etching
- Larger message area sizes available
Jumbo Run-DMD display/clock common features:
- Plug and play as a Jumbo Run-DMD clock
- Run-DMD controller with SD card
- Jumbo sized LED panels for 32 x 128 pixel resolution
- Black glossy top and bottom trim
- Custom edge panels with power, SD card access, and buttons
- Heavy-Duty hangers for wall mounting with 32" spacing
- Power supply (5v/10a)
- Power cord (US Grounded - 4' or longer)
- Custom laser cut acrylic frame
Jumbo Run-DMD display/clock Red version unique features:
- Run-DMD Edge controller required for Red panels
- 2x 32x64 Red LED panels
Jumbo LED DMD Display/Clock RGB version unique features:
- Cutout to allow access to switches to set colors
- Switches can be set to show red, green, blue, yellow, magenta, teal, or white
- Run-DMD White controller required for RGB panels
- 4x 32x32 RGB LED panels
We also have Run-DMD pinball displays and kits including all the components to turn your newish Stern DMD you removed to install a ColorDMD into a beautiful Run-DMD display. PM me to order one.
Standard Run-DMD Display Family
Jumbo Red Run-DMD display with Edge-lit frame. Choose your color and LED mode.
Jumbo RGB Run-DMD display with Edge-lit frame with custom message - Choose your message, font, and graphics!
Standard Run-DMD Display Family7a3bb93987ea8a60628659d9a875df724a27c5f2 (resized).jpg
Jumbo Red Run-DMD display with Edge-lit frame. Choose your color and LED mode.20190818_131206 (resized).jpg
Jumbo RGB Run-DMD display with Edge-lit frame with custom message - Choose your message, font, and graphics! 20190702_233828 (resized).jpg
Jumbo RGB Run-DMD display with Edge-lit frame with custom message - Example Graphic 20190702_233831 (resized).jpg
