New! Dark mode!
(Topic ID: 62569)
Jukebox Pricing?
By abc12346038
7 years ago
  • 33 posts
  • 17 Pinsiders participating
  • Latest reply 1 year ago by Isochronic_Frost
There have been 19 images uploaded to this topic. (View topic image gallery).
#1 7 years ago
Can anyone point me to someone or something that can provide me with current market values/pricing on jukeboxes?
I would appreciate it very much!
Thanks in advance,
Jeff
#2 7 years ago
Hey Jeff, is there a particular jukebox you're looking at? My dad's a jukebox collector - I could check with him for a resource if you're looking for a large list of prices, or could ask him about a particular box if you want.
#3 7 years ago
I might be able to help as I keep my eye on them and I've owned and restored a few of them over the years. Currently right now, I have a 1954 Seeburg HF100R. I posted a restoration thread about it a few months back with lots of pics.
#4 7 years ago
I wish i could find someone to work on my 1958 AMI-120. I've done most of the cosmetic part myself, but the mechanical part stumps me.
#5 7 years ago
I went through this same decision process a couple of years ago. At first I was only interested in one of the older machines that only played 45s. I looked at a couple (Seeburg and a Wurlitzer) but then realized this was not what I wanted. After considerable research we bought a Rock-Ola CD Blubber Jukebox (Walnut). It holds 100 CDs. We pretty much have it full (96 or 97 CDs). However, I must say that we use the iPod probably 90% of the time. I don't know how many total songs we have but it is in the thousands. We listen to music every day. It sits in our living room - the colors are very impressive (especially at night). When a guest enters our house they invariability head straight for it. Very good sound. A new one will probably cost somewhere in the $6,000 range - give or take a few hundred. If I could only keep one - my Tron Pro or my Rock-Ola Jukebox.... goodbye Tron. Do yourself a big favor Jeff, get a Rock-Ola or a Wurlitzer CD Jukebox.
#6 7 years ago
Quoted from RockChalk:
Wow, that looks fantastic! Nice work!
#7 7 years ago
Thanks E_N_3 The good thing is that it is a unique jukebox...the bad thing is that it is a unique jukebox. Hard to find anyone that knows how to work on the record mechanisms.
#8 7 years ago
Quoted from Collin:
Thanks, Collin!
I PM'd you via Pinsidemail.
Jeff
#9 7 years ago
Quoted from jamesdeloris:
James,
This is very helpful information and I appreciate your feedback!
I *love* Rock-Ola Bubblers!
Thanks,
Jeff
#10 7 years ago
Quoted from hassellcastle:
Hey, Craig!
I PM'd you...
Thanks for the reply to my post!
Jeff
#11 7 years ago
Your cosmetic work is stunning!
Excellent work!
Jeff
#12 7 years ago
I too am looking for prices on a jukebox... I have an opportunity to pick up a 1967 Seeburg SS160 (picks up a record but immediately puts it back and needs a little bit of cosmetic work as well). Thoughts on what it might be worth? Is the anything in the jukebox world similar to the Mr. Pinball price guide?
#13 7 years ago
On the Seeburg SS160, check your limit switch. There should be a microswitch that is tripped when the record gets to the end of playing, and returns it to the carousel. My Seeburg HF100R developed a problem such as this and it ended up being the limit switch. It would pick a record up to play, drop the tone arm to play, and then immediately put the record back up and go to the next record. Being that it was from 1954 and a micro switch from 1954..that isn't very MICRO if you know what I mean. I was able to take it apart, clean the contacts, put it back together and it's working like a champ again.
#14 7 years ago
Rockchalk
To bad you arn't closer to Denver, I have an AMI/ROWE tech in our shop. If you wanted to bring it to Denver I'm sure he would be up for working on it.
As for the OP. Can you tell us what kinda of jukebox you want? CD, 45, 78, Digital?
I'm a AMI/Rowe Distributor.
#15 7 years ago
Here are a few pics of my Seeburg HF100R during restoration and after.
LOVE IT! It's beautiful and sounds great.
Took it down to the frame.
#16 7 years ago
The finished product.
#17 7 years ago
Quoted from Gexchange:
Rockchalk
Denver is a lot closer than NY. Lot cheaper to ship something there and it would also be a good excuse for me to do some skiing this winter. Can your tech get something like this up and running again? It kinda worked when i got it...had to change the brushes in a couple of the motors, etc...seems like it is out of sync or something. Just too many weird switches, relays, etc...
#18 7 years ago
I have a Rockola 1454. Love how it pulls the records out.
#19 7 years ago
Cap kit maybe? Should be fairly easy for a jukebox tech. Will probably cost you 200-400$. I have a Seeburg DS160 that "partially worked" when I bought it. Fortunately, the Portland area has a Jukebox repair shop locally, http://www.nostalgiasounds.com/
#20 7 years ago
Quoted from nhm:
I had the amp rebuilt so the last part of the puzzle is to get the mechanism up and working correctly. Seems like there is some sort of timing issue with the basket assembly and when the arm grabs the record, etc... I had it playing when i first picked it up...i just need someone to go thru it and get it cleaned, lubed, and dialed in so that it works consistently. I'm 75% there with the restoration...just need to find someone to bring her home!
#21 7 years ago
Rockchalk
Thanks for the follow-up post!
I have PM'd you via Pinsidemail and am hopeful you can help to shed some additional light...
Thanks again,
Jeff
#22 7 years ago
Try Phonoland.com....they're a wealth of information!
Hope this helps.
Paul
Post edited by kamenoi_ostrow : wrong url
#23 7 years ago
I got mine for $450. Rowe r84. Plays 100 records (200 selections)
#24 7 years ago
Heads up, these are not very fun to work on. I have an issue with the mechs not returning the record to the wheel after the song is played. Anyone on pinside work on the mech boards?
#25 7 years ago
Quoted from dantebean:
True dat. I just bought a 1967 Seeburg SS-160. As far as pinballs go, I am a solid state type of guy for the most part so these EM-like jukeboxes are definitely a completely different world.
#26 7 years ago
Quoted from dmklunk:
My buddy bought an em Jukebox. It looked like a mess to work on. Got mine up and running now and in the basement.
#27 7 years ago
I think part of the reason why they're hard to work on is because they're so complicated and also because if even a single one of those switches get tweaked the slightest bit out of whack it becomes a nightmare pretty quickly. Amazes me how people manage to even upkeep the things.
#28 7 years ago
Are these worth anything? Got four of them in various working conditions. Heard the NSM brand was good, but obviously not collectibles. If anyone in So Cal wants them for parts or projects, let me know.
#29 7 years ago
Quoted from BR80:
JukeBox.jpg 57 KB
CD ones arnt worth much. NSM is good because they still produce parts.
3 years later
#30 3 years ago
Anyone know what this is worth?
#31 3 years ago
Quoted from pacman11:
Yes, 100 dollars but I will give you 200 for it
2 years later
#32 1 year ago
I am looking for the value of a Seeburg 100jl. It's part of a package deal and I know nothing about jukeboxes
Any help would be greatly appreciated.
#33 1 year ago
Anyone know who works on Jukeboxes in NY?? I don’t own any, but I have a few friends who keep bugging me since OBVIOUSLY pinball and jukeboxes are basically the same thing!
If I had someone to direct them too that’d be awesome
$ 999.00
G-Money Mods
$ 40.00
Arcade Arts
$ 179.99
$ 79.95
pinballmod
$ 38.00
YouBentMyWookie
$ 119.95
Allteksystems
$ 58.00
$ 69.95
$ 75.00
Whitewater pinball mods
$ 89.99
$ 54.99
CzTV Mods
$ 69.99
$ 11,500.00
Pinball Pro
$ 48.00
$ 26.95
$ 40.00
Arcade Arts
$ 7.00
APB Enterprises
$ 84.95
$ 38.00
$ 218.00
$ 19.50
Apparel - Unisex
ArcadeMade
$ 69.00
The MOD Couple
$ 12.95
COINTAKER.COM
