Righty ho. Some of you guys will be aware that a few of us have been working on something to replace Fat Wolverine (c) in Xmen.
I designed some plastic brackets to lift Wolverine up a little, which worked ok ... but really, it wasn't the ultimate solution I was looking for. The problem with the factory Wolverine figure is that he is just tooooo bigggg. If it had been 2/3rds the size, he would have been fine.
John Borgs original blueprints for the game show a captive ball there, and you can see a captive ball in the whitewood shown on Sterns "Making of Xmen" video.
Keith Elwin had so many Wolverine figures break (his LE is on location) he adapted a Stern captive ball to fit. While this works 100%, it didn't address the big routing in the PF where Wolvie sits without making up a plate for the assembly to sit on.
Judremy designed a block and had it made from Aluminium. I suggested that the best idea was to get the design plastic printed, and so we did. I got the files from him, and cranked one out.
I used an old switch I had lying around from something and modded it up to suit. My mates plastic printer is an older one, so I needed to do a little sanding to make it work (newer printers would be fine) Note the design ... the grooved bit is where the smaller ball sits (behind the captive ball) This part protrudes up through the routing. Very clever design.
This design uses a TOTAN style captive ball. This bolts through the bracket. I can't see it ever breaking.
Nice shiny balls! And on the bracket too.
And finally, here it is installed. Note that there was a little timber showing on the PF around the ball, so I just coloured it in carefully with Sharpie for now. Ideally, a little decal with some artwork on it would be neat here, but not crucial. Note also the Pole Dancing Wolverine Mod
Heres a comedic video Danielle and I made of it! I'm working on my comedy routine ...
Cheers to Judremy for his design .. this is all his work.
I believe he is getting some prices to have these brackets made up .. I highly recommend them.
You need the plastic bracket, a standard switch, a standard TOTAN style captive ball, and a small ball bearing (as the centre ball) The whole job takes less than an hour I'd say. If the mod came "ready to go" you could swap out Fat Wolverine (c) and the mod in 15-30 mins, no sweat.
cheers!
rd
