(Topic ID: 91040)
Judging Interest: W?D Who Dunnit Slot reels - new design reproduction
By PTHermes
7 years ago
  • 53 posts
  • 23 Pinsiders participating
  • Latest reply 6 years ago by nocjef
  • Topic is favorited by 10 Pinsiders
There are 53 posts in this topic. You are on page 1 of 2.
#1 7 years ago
Hi all, I just picked up a W?D and like many, the slot reel hubs are cracked. I am working on having some replacements made from new Acrylic (AKA Plexi-glass). If they work out on my machine I can have more sets made, just wondering how much interest there would be out there in community for a part like this.
#2 7 years ago
Count me in for a set.
#3 7 years ago
Me too.
#4 7 years ago
I am also in for a Set!
Great Idea to make Replacements
#5 7 years ago
I would be in for a set!
#6 7 years ago
I may take two sets
#7 7 years ago
I don't own a W?D but I've got a feeling that there would be a lot of people interested in replacements - almost every machine has the slot reels warped and nobody manufactures them.
#9 7 years ago
+1
Count me in, can always use a back up solution.
#8 7 years ago
double post, sorry.
Post edited by FalkenZR: error
#10 7 years ago
OK everyone, thanks for the interest. I am probably about 1 month out from having the prototypes done, I'll post some pics after I get them mocked up.
#11 7 years ago
Sweet, I'd like a set! Look forward to the updates, thanks.
#12 7 years ago
Quoted from dmklunk:
Yep, same here. It's a game that I've wanted for a long time, so I'd probably be up for a set to have handy for later on....
#13 7 years ago
Just a quick update, parts are designed and the prototype run of 6 reels is on order. It will be a 3-piece design, center hub made of aluminum to attach to the motor via set-screw, Plexi hub and Plexi tub.
Does anyone know if the opto-sensor can see through the plexi, or is the "notch" in the original required for it to function properly?
Should have pics in 3-4 weeks with my current work schedule.
#14 7 years ago
there is a notch at the edge of each wheel, the decal isn't transparent
#15 7 years ago
Each reel is different and they are not interchangeable.
#16 7 years ago
Quoted from tracelifter:
Each reel is the same, each label is different and must go in a particular order for opto reading to agree with DMD readout.
If I recall it's 3A then 1A then 2A, I could be wrong
#17 7 years ago
I guess I am just questioning if the label is enough to trip the opto or if I will need to notch the plexiglass. I will do some experimenting with masking tape. I have 2 weeks before I get the center hubs.
#18 7 years ago
Thanks, for the updates can't wait to hear more.
#19 7 years ago
count me in for a set.
#20 7 years ago
I'm interested in a set as well. Any idea on price?
#21 7 years ago
Put me on the list
#22 7 years ago
I would be interested in one
#23 7 years ago
Really need a set of these so good luck.
#24 7 years ago
I don't even have one yet but I may purchase. I hear these are impossible to find.
#25 7 years ago
Quoted from tilt-master:
That sounds right, it has been awhile since I repaired one of these.
When I put it back together I went in 1 2 3 order and that was wrong.
The motors are the same ones used for the SSTIF backbox spider.
You can repair the reels with a collet and true them but it is a MAJOR PIA.
Strike a flat spot on the motor shafts with a file otherwise you crack the reel spindles trying to get them tight enough so they don't spin on the shafts, the reason most of them are cracked.
I found probably the last NOS reel unit on the planet and it was 500 bucks + shipping.
The center ramp is also impossible to find, so is the sewer weldment.
There are also some bootleg repro translites out there, they look good until you put it in the game and back light it then it looks like ass.
If you find one of these games FS and the slot is sluggish or doesn't match the DMD pass on it, I won't even shop another one.
New reels and ramp are really needed for this title, most of them are toast.
Pretty cool game, was going to be called CLUE but MB rights were too expensive so they changed the name and the graphics.
#26 7 years ago
A couple in process teasers . Still waiting on the aluminum center hub to attach to the motor
The wheels are about 1/8" wider so the decal won't be "over" the hub area. Going to have to do a really good job securing the wires so they don't interfere.DSC07434.JPGDSC07435.JPG
#27 7 years ago
Nice, did the opto read the plexi or do you need a notch?
#28 7 years ago
Also for anyone repairing the slot machine; if the decals are installed properly the numbers in the corners get covered up, here is a picture of the proper wheel order based on the seams being aligned.DSC07440.JPG
#29 7 years ago
Since I don't have the hub yet I can't attach and perform the trial.
#30 7 years ago
It is also fairly easy (although a bit nerve-wracking) to straighten out a warped reel if you have a decent drill press and a heatgun or propane torch. Details can be found on RGP.
#31 7 years ago
Quoted from swanng:
https://groups.google.com/forum/#!topic/rec.games.pinball/kHPlAmQbncU
#32 7 years ago
Nice job!
#33 7 years ago
Looking good so far.
#34 7 years ago
Update pictures, the thinnest acrylic tube I could get was 1/8" wall and it doesn't fit through the opto-switch. I will be turning down the inner diameter as soon as I can get some open time on the lathe at work, probably a week or so for the next trial.
Update pics, cemented together and with hubs:DSC07443.JPGDSC07441.JPGDSC07445.JPG
#35 7 years ago
Looking good man! These are badly needed.
#36 7 years ago
Hope you will find a solution!
Thx for all your work
#37 7 years ago
I finished up the set yesterday, just got them installed tonight, but they aren't working properly yet. Since I was afraid to waste a set of decals I just coped them onto standard paper and used some packaging tape to put them on. With this set-up, the opto trips like crazy in the test menu; and just spins forever on a slot spin. Going to have to try to cut the notches out and maybe try some masking tape instead of packaging tape to see if it can block the opto-switch better.
#38 7 years ago
Update: The opto-switch was reading through the paper in some areas; used some painters tape for the 1/4" that passes through the opto-switch. Got the first set working 95%. The center wheel lines up on the line 100% of the time, but the other wheels go slightly past center and the symbol is correct, but just past the center line. I'll get some more pics over the next couple of weeks.
#39 7 years ago
How are you approaching the outer wheel alignment issue? Seems like you are really close.
#40 7 years ago
@Methos - I am going to try another copy of the decals to ensure I aligned the notches perfectly, next I am going to try swapping motors to see if maybe they need to be replaced. Judging by the wire colors on the middle motor it is newer, or at least different. I am leaning towards it being the motors because each symbol seems to repeat it's location, but they aren't all equally below the line; if that makes sense.
I am getting very close, but with how much machining is required on the plastic they won't be cheap to make.
#41 7 years ago
After some trial and error I have successfully made a full set of wheels! Slot is matching the DMD 100%, Wheels 1 & 2 line up perfect, Wheel three is slightly off, like maybe 1/8" away from being on the line. While I was at it I replaced all three motors per this post: https://pinside.com/pinball/forum/topic/15-who-dunnit-and-scared-stiff-motors worked out great. I still only have a "copy" of the decals installed with packaging tape over the wheels; looks good enough that I may just leave it. I will have to get some video this week.
#42 7 years ago
Sounds like a very ambitious project. Kudos to you and your passion to create replacement wheels for W?D. I'm sure there is a pretty good market for a set of three robust reels, at least, more robust than the OEM reels. Years ago I purchased a complete spare reel assembly before they became unobtainable in the event my original one failed.
I believe Bay Area Amusements has the reel decal sets (all 3) for $39.00, in the event any one needs a set.
Greg
#43 7 years ago
First, glad to help you get your motors on the cheap.
Second - I applaud your efforts to reproduce these wheels with a better and stronger replacement.
Pretty much every WD I've worked on has the set screw surrounding plastic broken, glued or zip tied.
Badly needed part and you should sell a bunch over time if you can get them done economically!
#44 7 years ago
My set screws are cracked on two of my wheels. I have a tight wire around them, but it slips too often.
#45 7 years ago
Got a set done and functioning 100%!!!
In order to get the optos to read the slot properly I had two options, a darker color, or use the replacement decals I ordered. The replacement decals don't compare to the originals - it really shows on the extra ball.
I also had to slot the optos a little in order to get the wheels to fit properly.
So I photoshopped the background to purple, printed it on gloss paper, and used packaging tape to attach to the wheels, I think they turned out great.DSC07455.JPG
Videos here (sorry LEDs don't work well with GoPro):
#46 7 years ago
Nice work!!!
#47 7 years ago
Looks great - great job on a much needed part.
#48 7 years ago
Count me in!
1 month later
#49 7 years ago
I've got one extra set of these available for $90 + shipping. Send me a message.
#50 7 years ago
PM sent for the extra set of reels
Thanks,
Jody
