(Topic ID: 173070)
Judge Dredd - Unlimited Multiball?
By brenna98
2 years ago
  • 18 posts
  • 10 Pinsiders participating
  • Latest reply 1 year ago by trueno92
#1 2 years ago
Having a sporadic multiball issue with JD.
Multiball usually starts out with the ball-save flashing for a few seconds then goes out. When you drain all but one ball, it returns to normal play.
I've had a few games where the ball-save light goes off, but it continues to kick balls out for an unlimited amount of time. Eventually, the game will say Slam-Tilt, then reboot.
Ball trough opto issue?
#2 2 years ago
Yup ball trough issues.... flakey opto / cold solder joint or even wire lose in the molex connectors
#3 2 years ago
Quoted from bigd1979:
ball trough issues
Thanks! I'll reflow and report back.
#4 2 years ago
I start with changing all the transmitter optos on the transmitter trough opto board. That is where majority of the issues start on this game.
#5 2 years ago
Ok. I reflowed the solder on all the Optos in the ball through.
Looks like the unlimited multi ball only happens during the ultimate challenge.
But again, it's not every time.
I'm running rom L-7 in case that has anything to do with it.
#6 2 years ago
Yes, had this a couple of times as well. Couldn't figure out where it was coming from, I never had (obvious) ball through errors. Maybe the occasional ball count errors because I whacked one out of the planet though...
I'm running on the deadworld mod rom, so that's like version L-0.1 or something. Really want a deadworld mod rom that has been fully updated.
#7 2 years ago
Anyone else have thoughts on this?
#8 2 years ago
I've had this happen a couple of times, I believe that depending on the settings, every now and then it will throw a random multi ball
that will seem like it never stops. I get the same thing on my STTNG, it will throw you a random ball, I think just to F-- u up.
#9 2 years ago
Quoted from brenna98:
Quoted from PinballManiac40:
#10 2 years ago
My JD has a similar issue. Every once in a while a normal multiball will spit unlimited balls until the 4 judges have been destroyed and the ultimate challenge starts and then the game will go back to playing normally. I discounted it being a trough issue because of how reliable it goes back to normal. I am thinking it may be a dead world mod issue. Yours may be the same bug/glitch?
#11 2 years ago
No. Mine has the dead world mod andhas no random failures
#12 2 years ago
From Pinbits website.
Troubleshooting Notes
The locking software is very sensitive to hardware errors in the game. A few typical malfunctions and their fixes are as follows:
Diverter does not load the ring when planet lock is available
- Check ramp entrance opto
- Check diverter
Multiball does not have all 6 balls
- Insufficient balls in the machine
- Trough divots holding up the balls (gently file and sand the trough ball lane to remove them)
- Bad opto transmitters or receivers in the trough (check trough optos in swicth test)
Game keeps shooting extra balls in multiball, and ends ball with balls still on the playfield
- Check crane exit opto
- Check that the ball exits through the crane exit opto
The crane opto has a relatively long gap; cleaning the transmitter and receiver can help.
https://www.pinbits.com/index.php?main_page=product_info&cPath=13_8&products_id=136&zenid=b9c7f3f72472708939fa35ed69d9d1c2
#13 2 years ago
MY JD did a multi ball on the second ball, and never lost track of balls, ran for what felt like 3 minutes straight.
I have the dead world mod. Don't think its a error, just random multi ball.
#14 2 years ago
My JD also experiences this exact issue as described by the OP.
Running L1AT with Deaworld Mod.
#15 2 years ago
Things have been better. With the reflowed solder on the through optos.
I had one hell of a game with no unlimited multiballs.
Ran through the ultimate challenge 3 times. Ended up with over 3 billion for a score.
1 year later
#16 1 year ago
anyone know where I can get a molex connector for the 4 pin opto on the 6 ball trough of my JD? I had a dead opto causing it to keep kicking a 2nd ball into the shooter lane on every game, ordered new opto boards thru pinball life (homepin) and the larger connector works fine, but the 4 pin side, was soldered straight to the old board, bypassing the connector all together..anybody know what part number i need to re-attach a connector? Thanks so much!
#17 1 year ago
The plug you need is available from many places - I have linked the parts required all available from GPE below.
I would be happy to post you a plug but it would probably take over a month to arrive.
5 pin housing:
https://www.greatplainselectronics.com/proddetail.asp?prod=CP100-05-LR
Pins (4 x reqd):
https://www.greatplainselectronics.com/proddetail.asp?prod=08-52-0123
Polarising pin (not really needed but nice):
https://www.greatplainselectronics.com/proddetail.asp?prod=15-04-9209
#18 1 year ago
I had the same issues woth demolition man and it was wires going to the trough.
I tested it with getting into.switch levels and knocking on various parts of the pf where vibration could kick the optos into.flickering on the levels test.
I think you are having the same thing
$ 19.95
$ 28.00
$ 159.99
€ 95.00
FlipperLED
$ 229.99
Fort Lauderdale, FL
Killeen, TX
Yorktown Parts and Equip
$ 69.99
$ 8.50
Bright Lights Pinball
Trade
Machine - For Trade
Louisville, KY
$ 47.00
$ 29.50
Playfield - Plastics
$ 99.99
$ 65.00
Cabinet - (Alt) Translites
$ 259.99
PinballBulbs
$ 69.99
Killeen, TX
