(Topic ID: 285418)
Judge Dredd Please Help !! no flippers and balls keep launching
By mobilexx
1 year ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by mobilexx
    #1 1 year ago
    I have a Judge Dredd that when you start game, just keeps putting balls into the shooter lane, then you press the launch button and it keeps launching balls and wont stop, even if I set the tilt , it will stop the dmd but keep launching balls, the flippers wont work at all, they will in test mode though, but the flipper buttons wont register on the test matrix... fuses are all good, not sure if problems are related or separate issues.
    Any help would be greatly appreciated ..
    Thanks !!!
    #2 1 year ago
    Update.. I cant get any optos switches to register on matrix, beginning to think the problems are related due to optos for flippers and optos for trough ..
    #3 1 year ago
    Power board has 5v at the 5v post, 12v at the 12vr, and 0 at the 12vu..
    #4 1 year ago
    Had the same on mine , was a result of acid damage and broken components on main board releated to the matrix , these components sit's directly under the batteries.
    Start by using the test functions to see if you have issues in row or colums , all or as in my case two of them
    Regards
    Terje
    #5 1 year ago
    First take out all the balls, 6 of them...then put the game in switch test and check the drain switch. The one that's in middle of the apron see if its behaving correctly. Then check the trough optos, drop one ball and see if all the optos are registering. Then ball 2 through 6..you should see all the trough switches registered. Lastly look in the shooter lane and make sure the switch is not stuck on....report back
    #6 1 year ago
    I had the 12vu repaired on the power board, now the optos seem to work, also had a repair to thempu board for volume down button not working, but now I have a similar issue as Huldra66 mentioned, rows 1 and 2 on the matrix will activate together, if I test switch 12, it will acitvate 22 also, He said all the switches were working when he tested board and said it was fine.. question is, could it be in my wiring ?
    I removed j212 and it still did it, then I removed 209, and still has the same issue..
    Thank you guys for your help
