(Topic ID: 266162)
Judge Dredd missing letters on DMD
By mermaidlover
1 year ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Crash
    #1 1 year ago
    Judge Dredd letters on DMD are missing. Have replaced ribbon cables. Have repaired DMD controller and swapped with a known good one. Using a Rottendog MPU because of battery damage on original. replaced bottom connectors on MPU. Don't have an MPU DCS to swap. Can anyone help? Won't go into test, but test button works and causes sound like a muffled gunshot. First image is what displays when test button is pressed. Weird. Thank you for your help.
    Judge Dredd 1 (resized).JPGJudge Dredd 2 (resized).JPGJudge Dredd 3 (resized).JPG
    #2 1 year ago
    If you can't get into tests sounds like a CPU board connection issue, are there dip switches on that particular rottendog cpu?
    Maybe reseat the chips on the CPU too?
    #3 1 year ago
    Reseat the game roms
    #4 1 year ago
    Whoa, that's bizarre. I've never seen anything like that that. It appears the ASCII text data streaming from the CPU to the DMD controller is getting corrupted.
    #5 1 year ago
    The data from CPU to DMD controller is bitmap images, not ASCII text. Looks like DMD controller RAM addressing problem. Maybe the buffer chip in CPU board, that outputs data/address to DMD is failing.
    #6 1 year ago
    You're right, I forgot the image data is in the CPU ROM on WPC games.
