I have just repaired a Judge Dredd pinball machine that had really many gremlins hidden
Acid leak and several bad components on the main board, Deadworld not spinning and loose gear in gearbox as well as one damaged gear, now set up with led's and all cleaned, seems like only issue now are the left flipper coil getting hot and weak in periods ( replaced with new )
while playing there are times it becomes weak , and by measuring the voltages it looks like from time to time it does not shut off the current trough the "Main" coil, and keeps running current trough both coils while holding.
But not fully as voltage flickers around 25v over the main coil and usually just for a short time , meaning this is a periodic failure and just a short time so a bit tricky to start measuring why on the flipper board.
Anyone seen the same symptoms before ?
Regards
Terje
