Need some advice. I moved my dredd and now it wont come on. At all. Nothing like its not plugged in at all. I know the outlet works and the game worked fine before I moved it. Advice? Where should I start??
Check the fuse on the power supply?
Of course make sure the pinball end of the plug is still connected
Well, see if that outlet inside your game has power. It should have power even if the game is off. If that outlet doesn't have power, then you have a cord problem or that fuse possibly. It is a service outlet for plugging in soldering iron's etc while the game is powered off. I have used it several times on my JD.
If you blew the main fuse, you would get nothing.. no lights.. nothing at all.. start there... also check to see if the cord pulled loose on the inside of the cabinet.
If you open your coin door and look to the right, you will see a silver metal box with a black cap on it, twist off the cap and check the fuse inside that.. if that is dead you will get nothing as you describe.
You checked all the connections behind the backglass? Maybe the cord was pulled and tugged a wire inside the cabinet?
Quoted from balboarules:You checked all the connections behind the backglass? Maybe the cord was pulled and tugged a wire inside the cabinet?
And double checked the power cord didn't get pulled out, where it attaches to the back of the cabinet?
Yes, the above is very important!
Quoted from practicalsteve:And when you checked the fuses you pulled them and used a meter right? Not just a visual check.
Yes, VERY important! Use a meter if possible
Could be the main varistor in that main power box as well. Could be a bad cord as well.
Get a high voltage tester, the wand kind you can just place near something and it lights up if over 60v. Trace from the wall, over the cord to the box. This is a very simple circuit to within the power box, and from there it's the fuse or varistor.
Quoted from joekiss:Will my meter do the high voltage thing??
Well, not with a quick wave like the other tool. You would have to take the box apart and measure at the hot and ground, but I would only recommend that if you are very comfortable with electricity, as there is full 120v wall voltage. So long as the machine is plugged in, inside that box, the hot is always live prior to the switch connection. The wand thing (not sure what it's called) is great for many home uses, and like $15.
You could try swapping out the power cord, could be that has a problem, it can happen.
Have you checked to make sure your transformer is tapped properly for 120v (butterfly) since it might be a reimport?
viperrwk
Do you have voltage at connector J101 on your driver board? pins 1&2 red wires should have 9v AC, pins 4-7 blue/white wires 13v AC. That's coming direct from your transformer, so if no power there, the transformer must not be getting power.
Does that connector look good too? Not browned from heat damage like you sometimes see on GI connectors?
I literally moved mine from one side of the room to the other and had no power. Turned out to be the small ???Varsitor??? (Not sure if thats the name or not?) separated from the vibration I guess. Either that or it was just stressed and ready to go anyways. Its a small grey ceramic looking cap under your meter. You can see it in your first pic there. Check it to make sure its not cracked or separated. If you have a DMM, test it for continuity as well. Couldnt get the same part but had an equivalent at Radio Shack. Good luck
Ah, see that its already been mentioned. Didnt read all the posts..... But yeah, be sure to check that.
hi joe,you have to put the leads into the jacks on the meter.you can't test voltage the way you have it on the wire.that way only measures amperage.take the cord out of the back of the game .put black lead from meter into left slot on plug,put the red lead into the right slot on the plug.meter set to vac.do you have a reading. take a pic.also take a pic of the service box without your meter in the way. g.l.joe
Do you understand how line AC is wired?
120v AC, Black is Hot, White is Common, and Green is Ground.
DMM to AC, touch one probe to Black and the other to White, and you should see about 120v
Black to Green is 1/2 the circuit, so it's 60v, and White to Green is the other 1/2, also 60v.
Green is just the ground wire.
RM
Quoted from joekiss:Looks like there is current going into the on/off switch but none coming out. What now???
I had a bad on/off switch on one of my machines. $5 part at the local electronics store.
Quoted from RussMyers:Do you understand how line AC is wired?
RM
I don't understand a thing just taking advice and hoping I don't get zapped. So the black wire should show something also?? White is the only wire with anything coming into the machine.
If you don't know what you're doing, you're playing with some dangerous stuff.
Quoted from RussMyers:Black to Green is 1/2 the circuit, so it's 60v, and White to Green is the other 1/2, also 60v.
?? Measuring across the hot to ground should give your 120, as will hot to neutral, neutral to ground should given you 0.
Quoted from Atomicboy:If you don't know what you're doing, you're playing with some dangerous stuff.
I may be wrong about that part.
RM
Put one lead on the green connection and one on the black: what does your meter say?
Put one lead on the green and one on the red: what does your meter say?
there should not be any power to the white connection, it is the neutral wire. Don't bother with it.
If you get readings, you at least know you have power to that point. If you get nothing, trace the wires back to a previous connection and test again, same process. You need to find where power starts/stops.
This is electricity 101. If you get power in the first tests I typed, the other pinhead shere can tell you how to test the right side of your pic. I'm assuming that box is an inverter, but I'm not sure.
The box is a EMI filter. So, you should get 120VAC from the black to green and black to white on the left side of the filter, you should also get 120VAC on the right side of the filter (black to white wires) if you do not, the filter needs to be replaced. The filter removes any line noise before it goes into the machine. Remember your reading may not be exactly 120VAC this can fluctuate slightly.
You also want to check continuity on the switch which is connected right after the filter. Basicly if power is coming out on the right side of the filter the black and white wires then go to the switch. flick the switch on and see if there is power on the other side of switch on the black and white wire. If there is not, then the switch is bad.
This is not a replacement for the game just an FYI.
ebay.com link: Taishing TSC 10BA1 EMI Filter 250VAC 50 60Hz 10A
Very basic meter instruction.
That's a broken thermistor. It's a current inrush limiter, high resistance when cold (and the game is first turned on) and then resistance drops to almost nothing when it warms up after a second or two. It is supposed to reduce stress or electronic components at turn-on.
You just have to de-solder the old one and solder in a new one.
It's not absolutely needed, you could just solder a plain wire connection there, but it's probably best to replace it with a new one.
RM
This is a replacement:
Part Number: B57238S0259
Inrush Current Limiter
15% Discount for purchase of 10 or more
Thermister, NTC
2.5 ohm, 8.4 Amps
Alternate for CL30 as used by Williams (Williams part number 5016-12978-00)
Manufacture:Epcos
Price: $1.25
https://www.greatplainselectronics.com/
RM
This page was printed from https://pinside.com/pinball/forum/topic/judge-dredd-is-dead and we tried optimising it for printing. Some page elements may have been deliberately hidden.
