Does anyone have any tips for removing the deadworld gearbox on JD? I need to send it out for repairs. Just eyeballing it, seems like a huge pain in the butt to remove. Do I have to remove everything topside, or can I get ways with only removing stuff under the of? Seems like I have to remove the entire planet on the top then, I can extract it from the bottom, shaft and all. However just removing the planet makes no sense-- how does one unscrew the shaft bolt when it is obstructed by the lamp board/metal disc?? So confused...any help would be greatly appreciated.
