My bottom right flipper stopped working all of the sudden. The upper right flipper works just fine. The spring, connections and solder points all look good. Any tips would be greatly appreciated, thanks!
Tests - Switch Edge - Push right flipper button in slowly - do both optos register on the DMD register one at a time, lowers then uppers ?
Coil lugs - dig around for bad solder joints or cracked wires from lug to coil.
Fliptronics board - pull and check fuses with a meter.
