(Topic ID: 206802)
JUdge dredd error on unused switch
By gipelo
1 year ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 1 year ago by at_t_2d
#1 1 year ago
Hi all,
I'm finishing the restauration of my judge dredd... but I still have some error on some switch: 28 and 32...
but when I look at the documentation , those switch are indicated as "not used" ...and they are not present on my playfield...
any idea ?
thanks
Gilles
#2 1 year ago
If those two switches are on the planet ramp, it may be the same issue that I had. I got the error when I put in a newer ROM chip to get the balls to lock around the planet. That is when I learned that two switches changed locations and numbers after the very early production games. I swapped back to the original ROM and the errors went away. All I had to do was install the planet ring with the holes instead of the slots for the balls and the ROM that came with the pin already supported the locking.
$ 229.99
$ 8.50
