Have a strange issue. Under heavy load the dmd starts to flicker and glitch out. I have had my boards repaired by lockwhenlit. And am running a new x pin display power driver board. I have reflowed the connections on the back of the display driver. Not sure if its a weak dmd. Or the ribbon cable is bad. Any ideas would help.
Video does a good job but the frame rate hides how bad it really is. The reflecation in the glass helps give you a better idea of just how bad it is.
