Please post a picture of the whole power supply. You started off with a high voltage problem, which is why the F7 is blowing a fuse. So it seems your high voltage needs to be rebuilt.
http://www.pinwiki.com/wiki/index.php?title=Data_East/Sega#Testing_DMD_HV_Power
Quoted from hollywood:Any ideas?
When I turn the game on, GI lighting comes on...but that is it. Nothing else happens. Advice is welcome!
Now, it also seems you may have a separate problem with your C2 leaking on your power supply so your 5volts. and I would have to bet the electrolyte ate up the trace under it. A good sign is if the board around the C2 looks wet, then this is what happened. Would be best to replace all the capacitors on the power supply. Also, disconnect CN1 and inspect it for any burnt pins.
http://www.pinwiki.com/wiki/index.php?title=Data_East/Sega#Missing_5VDC
If you upgrade to a ColorDMD, you would not need to worry about fixing the High Voltage section, though, you definitely would want to change all the capacitors, for the reason like C2 leaking.
If you go the route of just replacing the power supply with an aftermarket board, I suggest the Xpin power supply.
