(Topic ID: 243478)
Joust CPR playfield swap - process and tips
By j_m_
4 months ago
  • 86 posts
  • 11 Pinsiders participating
  • Latest reply 4 days ago by j_m_
  • Topic is favorited by 23 Pinsiders
There have been 89 images uploaded to this topic. (View topic image gallery).
There are 86 posts in this topic. You are on page 1 of 2.
#1 4 months ago
to start with, prepping the playfield will make things go much faster (and smoother). this includes, running a drill bit through all of the holes to remove the excess clear coat as well as opening up the holes to accept screws and bolts
the following is a diagram of one side of my original NOS playfield with the hole positions and sizes called out by color. quantities are [per side]. the value in [brackets] at the end of each line represents the diameter of the drill bit that should be used to clear out and open up the holes.
chris hutchins mentioned a tip in another thread that he uses during his restoration process. he will initially run a brand new [sharp] slightly larger, brad tipped drill bit (in reverse) to cut through the clear (without chipping it away) and then switch over the correct drill bit size and run it through the hole completely
(click to enlarge and see more detail)
TEAL
(2) flipper bat resting position roll pin locations [5/64" dia.]
WHITE
(6) ball guide wireform locations [5/64" dia.]
PURPLE
(12) #4 wood screws to secure wooden side rails [1/8" dia.] NOTE: these are the holes that should be counter sunk from the underside so that the screws are flush with the bottom of the playfield
MAGENTA
(51) #6 screw holes to secure hardware [5/64" dia.]
GREEN
(23) #10 screw holes to secure hardware [5/32" dia.]
RED
(4) #10 holes for playfield hanger brackets [5/32" dia.]
NOTE:this guide is merely that. I would recommend checking the actual diameter of the hardware associated with a hole before proceeding. the hole size for hardware that is threaded into the playfield should be smaller than the actual diameter of the threaded portion otherwise you will not be able to secure the hardware in place.
once all of the topside holes have been cleaned out, the playfield can be flipped over so that you can perform the following:
- install the ground braid for the general illumination common ground
- install the lamp sockets for general & controlled illumination
- install t-nuts for the machine screw hardware & posts
if I can take a good photo of the underside of a playfield, I will document the lamp socket and t-nut placement (by type and size)
#2 4 months ago
lamp socket positions
lamp sockets
077-5000-00 qty: (30) [green] (15 per side)
miniature bayonet base 2-lead with staple down mounting bracket
4762 qty: (8) [blue] (4 per side)
miniature bayonet base 1-lead with short mounting bracket
note: part no.'s E-120-81 or E-120-84 can be used as substitutions
077-5003-00 qty: (9) [not shown] (2 per side under the cross over plastics)
miniature bayonet base 2-lead with laydown mounting bracket
note: (4) above playfield (under the crossovers), (5) in coin door area
077-5001-00 qty: (8) [orange] (4 per side)
miniature bayonet base 3-lead with laydown mounting bracket
note: part no. 077-5006-00 can be used as a substitution
077-5009-00 qty: (28) [magenta] (14 per side)
miniature bayonet base 3-lead with long mounting bracket
note: an additional 30 (15 per side) are tied together in sets with brackets (lighter magenta)
#3 4 months ago
hardware position (top)
top side hardware locations
237-6186-00 (12) [purple] #4 x 1" p-flh phillips, flat head sheet metal screw
NOTE: countersunk from the bottom of the playfield. these are the longer screws that secure the wooden playfield guides to the playfield
4106-01115-08 (29) [magenta] #6 x 1/2" pl-hwh-a phillips, hex washer head sheet metal screw, zinc plated
4006-01005-26 (16) [bright green] #6-32 x 1-5/8" p-ph phillips, pan head machine screw
4106-01033-08 (12) [white] #6 x 1/2" p-trh phillips, truss head sheet metal screw
530-5332-00 (2) [orange] #10-32 bottom, no tap on top bumper post
note: a washer sits between the playfield bottom and the #10 nylock nut used to secure the post. compressing and gripping the rubber sleeve from the topside will help keep the post from spinning while tightening the nylock nut from the underside
530-5012-02 (4) [aqua blue] #6-32 x 2" post stud w/ a hex washer head top
note: these post studs are secured to the playfield by threading into #6 tee-nuts
530-5005-01 (1) [yellow] #10-32 mini post stud
NOTE: two of the sling screws were changed from the typical wood screw to a machine screw on the CPR playfield to add a bit more stability to the star posts and the rubber rings. a tee-nut should be inserted from the underside for all 3 (non-adjustable) screw holes for each of the sling areas
edit (2019.jun.25): corrected the hardware callouts for slings. no impact on prepping playfield
edit (2019.jun.28): modified the colors on 2 parts to make identifying everything a bit easier
#4 4 months ago
the veritas plunge base works like a dream producing perfectly vertical holes. in order to give myself the additional height that I needed to accommodate the length of the drill bits, I fashioned a base out of some 3/4" thick plywood
with plywood base
using a 1/8" brad tipped bit, I just cut through the clear coat to prevent it from being chipped or cracked when tightening down the screws and other hardware
afterwards, I adjusted the stop on the plunge base to a depth of 3/8" and routed all of the holes where the #6 x 1/2" screws would be used using a 3/32" drill bit. the 3/32" diameter bit is equal to the size of the central portion of a #6 screw, not including the threads
for the 3 metal ball guides on both sides, I didn't bother to break the clear coat since the playfield would be visible. instead, I adjusted the stop and piloted the holes to a depth of 7/16" using the same 3/32" drill bit. this provided holes deep enough so that the bottom of the wire guides are in alignment with the mid-point of the pinball when firmed seated into place
holes drilled
guide set into place
height tested with a pinball
#5 4 months ago
prior to installing the hardware on both the top and undersides, you'll want to make sure that the bend was set to the correct angle. it should be 170° (if measuring it from the bottom, or 190° if measuring it from the top, giving you a slope of 5° on either side
CPR used square headed screws to secure the 4 plates, so you'll need to pick up a #1 square bit from lowes, home depot, etc.. to loosen the screws and then get the help of a friend to hold the bend to the correct angle while re-securing the screws.
on the playfield that I'm currently swapping for a friend, I've replaced all of the screws with the correct, original black oxide, sheet metal screw that is a #6 x 1/2" p-rwh-a (phillips round washer head A type point); part no. 4106-01022-08B
for those that want the screws but did not purchase them from me when I did the bulk buy last year, marco specialties and pinball life purchased my remaining stock and have them in stock
#6 4 months ago
there are 6 sections of the wiring harnesses (2 each for both the lamp and solenoid) that pass from the underside of the playfield to the topside
they are:
- auto shooter x 2 (each end of the playfield)
- ball drain kick-out x 2 (each end of the playfield)
- 2 bulbs under the cross over plastic x 2 (center of the playfield, near the pass through lanes)
in order to make the game a bit more serviceable in the future, I am going to cut the harnesses (the 2 sets of 2 wires for each coil) and terminate them with a 2-pin molex connector which is small enough to pass through the hole currently being used. this will allow the user to disconnect either mechanism to allow it to be serviced
lamp socket wiring harness
there are also 2 sections where GI lighting harness wire passes from below to above (2 wires on one side, 4 on the other) where the wires connect to a pair of laydown sockets. the wiring from these sockets will be run to a 2-pin/4-pin molex connector just below the playfield. again, this will improve serviceability if the case where the lamp harness needs to be removed from the game.
edit: photos for the final solutions will be added once I have completed the modifications
#7 4 months ago
the holes for the #6 machine screws and posts with the #6 bottoms on the CPR reproduction were drilled exactly to spec and fit a #6 perfectly. however, they are not large enough to accommodate the threaded shaft of a #6 t-nut, so you will need to enlarge the hole from the underside of the playfield using an 11/64" drill bit
I did so using a tape line set at 9/32" to ensure that I was only plunging enough to accommodate the threaded shaft of the t-nut and not disturb the clear on the top side of the playfield. there are a total of 17 #6 t-nuts on each side of the playfield (as seen here)
NOTE: you'll want use the 11/64" bit AFTER you've created the pockets with the forstner bit (see below), otherwise the enlarged hole will not be deep enough to accommodate the t-nut shaft
I also found that for the holes that run all of the way through the playfield (eg. all of the metal posts), it's much easier to run the drill from the underside of the playfield, up through the top. the way that a good, sharp drill bit bites into the wood that you are drilling into, it pulls the wood towards you.
NOTE 2: drilling from the underside greatly reduces the potential for cracking the clear coat or pulling off sections of the playfield where there is little wood in between cut-outs
due to the positioning of 4 of the holes being partially obscured by 2 of the bent brackets, you will need to use a forstner bit to create a pocket approximately 3mm deep for the t-nut to sit in under the bracket. a total of only 4 of the holes need be drilled with the forstner bit, but I opted to drill 8 of them (the inner two of the 4 lines of 4) just to play it safe (as well as creating 2 pockets to the spear top metal posts near the spinners
next up, laying down the braid for the lamps that are stapled down
#8 4 months ago
while waiting on the bare wire braid to arrive, I've been messing around to see if I can't tweak the "pattern" and bit to make it look a bit more symmetrical or neater using a bit of tracing paper. here's a first attempt. I just want to rotate that top left bulb a bit more so that I can change the braid locations and avoid the t-nut altogether
the key is to keep the braid out of the way of any hardware so that you don't inadvertently ground out something that shouldn't be
#9 4 months ago
here is a photo for the P2 side showing the lamp sockets with the 3/8" long #6 yellow zinc plated hwh (hex washer head) screw positions
#10 4 months ago
in order to try and make sense of the larger switch and lamp harnesses, here are some images with just that particular harness laid on the playfield to give a rough idea of how each harness "flows"
switch harness positions
lamp harness positions
#11 4 months ago
reserved for a future post 10
part no's for post and screw locations
4106-01033-08
#6 x 1/2" sheet metal screw p-th-a (phillips truss head A point)
4106-01022-08B
#6 x 1/2" sheet metal screw p-rwh-a (phillips round washer head A point) black oxide finish
4106-01115-08
#6 x 1/2" sheet metal screw pl-hwh-a (unslotted zinc plated hex washer head A point)
4106-01115-06
#6 x 3/8" sheet metal screw pl-whw-y (unslotted yellow zinc plated hex washer head A point)
4006-01005-26
#6-32 x 1-5/8" machine screw p-ph (phillips pan head)
4006-01027-04B
#6-32 x 1/4" machine screw p-rwh (phillips round washer head) black oxide finish
#12 4 months ago
This is awesome! Cant wait to see the progress, not to mention all the documentation will help me in the future!!
-Tom
#13 3 months ago
I'm hoping to start on the swap either this or next weekend. I've got a neighbor helping out, so it should go rather quickly. the owner is allowing me to install new lamp sockets (and braid) and drop targets, but other than that, I will be re-using all of the existing hardware.
I believe it was mentioned in the other joust thread, but for those that didn't see it, marco specialities has re-produced the tombstone drop targets (used in the four 3-drop banks), but appears to be out of stock of them again
https://www.marcospecialties.com/pinball-parts/03-7773-4
#14 3 months ago
Quoted from j_m_:
I wish Macro had a "notify me when this part becomes available" option...
or a "please let me know and I will take X number once available"
#15 3 months ago
I have one of these arriving tomorrow to make short work of pre-drilling all of the holes to the proper depth and perfectly perpendicular to the playfield
veristas plunge base
http://www.leevalley.com/us/wood/page.aspx?p=73720&cat=1,260,43000,51208,73720
since I've got about 5 "swap projects" in the wings, so I figured this would be a good investment along with using mr. hutchins tip for pre-drilling the holes found here:
https://pinside.com/pinball/forum/topic/hep-this-week-9-17-18/page/67#post-5016367
dremel offers one as well which sells for about $35, but it is construction is all plastic and the reviews are not very good. I did a bit of research and this one appears to be pretty well made
#16 3 months ago
the plunge base arrived yesterday. it's very nicely constructed and well made. I need to pick up a piece of felt to adhere to the bottom so that it will glide over the playfield surface and a chuck for the dremel to easily swap out drill bits
I should be good to go this week to prep the playfield, getting all of the topside holes cleaned up and pre-drilled as well as the new braid and lamp sockets in place
#17 3 months ago
some progress was made yesterday. see post #4 above
waiting on screws to make lamp socket installation go smoother and then will start on stripping the original playfield, cleaning the harnesses and transferring everything over
#18 3 months ago
I'm hoping to have the underside completely stripped by the weekend and will try and post a detailed diagram on what goes where
I noticed that williams used #6 x 1/2" hwh screws for everything. I will be changing that out and using the yellow zinc plated #6 x 3/8" hwh screws for all of the lamp sockets. the reason for this is that the bracket on the lamp sockets is very thin metal and doesn't take up much of the screw thread length. given that the playfield is roughly just over 1/2" thick, you do not want to risk having a screw penetrate the topside of the playfield, damaging it.
the diagram will show all of the dimples where I plan on using the #6 x 3/8" long screws which should help everyone out
#19 3 months ago
I made some progress over the weekend stripping the underside of the playfield, removing over half of the components from the player one side
on the game that I'm currently working on, I'm attempting to keep the harnesses all intact (where possible) and finding that to be mostly do-able with the exceptional uncoupling of a wire here or there. I'm using id tag zip ties to identify where switches, coils and mechanisms are located (which is great, because they don't fall off like tape does or create a sticky mess and are easy to remove when you're done with them
harbor freight used to sell these, but do not any more. zoro.com sells them for $30 per 1,000 and monoprice has them even cheaper for $1.38 per 100
zoro
https://www.zoro.com/partners-brand-identification-cable-ties-4-pk1000-ctid45/i/G5725968/?utm_content=386144&utm_source=ExactTarget&smtrctid=278452&utm_medium=Email&utm_campaign=201903_OrderConfirm_Transactional_None_All_1
monoprice
https://www.monoprice.com/product?p_id=5792&gclid=EAIaIQobChMI26rfoZ634wIVBNbACh1NegGnEAQYFyABEgLDk_D_BwE
NOTE to self: if you're going to buy something like these, USE THEM!! I made the mistake of labeling every single one of the switch harness connectors (and very well, I might add), but did not duplicate this effort for the lamp harness.
trust me when I say that unless you plan to remove and swap everything in a single day (or you're chris hutchins and have done this 10x before), it's very likely that you will not remember the exact location for every single switch or lamp. photos on how the parts are oriented on the playfield before you remove them are equally as helpful when it comes to transferring everything to the new playfield.
finding broken wires on switches and noting them as I disconnect everything. these, along with re-soldering the wires that I'm having to cut to disassemble and separate the different (coil, lamp and switch) harnesses are labeled if I don't take care of it right away
additionally, I found that williams did not use the yellow zinc plating on the #6 x 3/8" hwh screws to secure the lamp sockets so I've been marking the holes with a gold sharpie inside the hole and next to it. this will help me create my template when I go to pilot the holes on the underside of the CPR playfield (and mark them as well so that I do not inadvertently use a 1/2" long screw in the wrong place
the screw holes and areas right near the holes are marked ["dotted"] with a gold sharpie to indicate the positions of the #6 x 3/8" hwh screws
#20 87 days ago
more progress made over the weekend (and more after this photo was taken)
I’m hoping to have the underside completely stripped this week and start transferring over everything
I’ve ordered a surplus of the 1N4148 zener diodes for the controlled lamp sockets to make the install a bit smoother. if anyone needs some, shoot me a pm and we can discuss
#21 87 days ago
did you add clear to the CPR pf and letting it cure off during this stripping process?
I am curious what the process would be for adding more clear since this is a bent pf.
#22 87 days ago
I did not add or re-clear the CPR playfield. I did let it sit (outside of the box) for a month to help it cure a bit more before I ran the brad bit to remove the clear around the holes and pilot all of the screw holes.
given that the original playfields were not cleared at all, I can't see where a [now] HUO machine would need any [more] clear than what was already applied by CPR (it seemed rather thick already. and without knowing what type of clear that was used, I wouldn't want to risk using something that would adversely react to the existing clear
with the underside getting closer to being completely stripped, I should be able to take a photo and supply an image with all of the holes highlighted where the shorter, 3/8" length #6 hwh screws go (basically, all the ones that are used to secure the thinner lamp socket brackets
#23 85 days ago
I finally am to the point where all (except the player 2 flipper) coils have been removed from their harness (and id tagged). as I reach the end of the teardown, I have noticed few things that I will make reference in the next update with photos that will hopefully save people doing this a bit of time
this playfield has definitely seen its share of use (and abuse). there are a number of wiring hacks near the center of the playfield where the harness passes from the underside to above (under the cross over plastics). I may end up taking the chris hutchins path and installing some molex connectors to de-couple the assemblies and lamp socket groups from the rest of the harness, making it easier to service in the future. additionally, this playfield has what appears to be a bunch of bondo underneath the playfield for the t-nuts near the 3-bank drop targets
the ones in particular are:
- the ball trough kick-out and auto launcher assemblies; both of these are top mounted assemblies with wires running through a small lamp socket sized hole underneath and are perfect candidates for molex connectors
- the GI top mounted laydown lamp sockets (2) along and the under playfield lamp socket that reside near the center of the playfield under the cross over plastics are another area where terminating them with a molex connector would allow easier serviceability
finally, an FYI
if you are planning on replacing the square headed screws for the brackets that hold the playfield at the 170° angle. when you remove the (2) inner brackets, that is the perfect time to install the 16 t-nuts for the metal screws and posts for the star posts located behind the 3-bank drop down targets. a portion of (2) of the t-nuts is concealed by the brackets
#24 85 days ago
How are you liking the plunge base? I keep going there, but haven't pulled the trigger yet.
#25 85 days ago
Quoted from BobLangelius:
it works great. definitely makes the job of piloting the holes a lot easier and faster [with a consistent depth]
#26 85 days ago
the one thing that I'm finding (but I'm not sure it the issue is related to this one specific machine or jousts in general) is that the switch, lamp and power harnesses all seem to be intertwined and cannot be easily separated unless you want to start cutting a lot of wires
this means that your options are:
- leave everything attached, and pull the harnesses off in one, huge tangled mess and try and work through it section by section
- strategically sever lines here and there at coils, switches and lamp sockets (marking them as you go) to try (key word here is 'try') and separate the harnesses and make them a bit easier to deal with when moving them over to the new playfield
obviously, I'll be taking the more difficult route and go with option B. in the end, it should make it easier on the tail end
#27 84 days ago
success!
someone obviously had re-worked and ran a new wire in the switch harness and wasn't very careful with their routing skills, causing the new wire to entangle both the coil and lamp harnesses in multiple areas. a few careful cuts and I now have 3 distinct and separate harnesses, which will make installing them on the new playfield much, much easier.
the playfield is now completely stripped top and bottom. photos to follow soon once I've put together the diagram for the bottom side dimples
and now the fun part starts . I would prefer to fix a lot more, but it's not in the budget for the owner
#28 83 days ago
TIP
a screw for each the 2 shorter wood rail sections (located left of the pass through from the player's perspective) may or may not be partially covered by the outer bent brackets
obviously, you will need to loosen the brackets in order to remove them. on the CPR playfield depending on how close to the actual center of the playfield the bend cut was made, you will need to also loosen these brackets in order to drop the screw in (and under the bracket)
there are 6 bent brackets used to secure the 170° bend, so loosening one of them at a time shouldn't change the formed angle, however I would use an angle protractor after the fact to ensure that you still have a 5° bend on either side
#29 83 days ago
detail for post # 6 was added above
as mentioned previously, this joust has seen better days. it appears that some of the t-nuts loosened and then were spun repeatedly, chewing up the underside of the playfield, rendering the t-nuts useless
bondo appears to have been used for a couple of the posts located behind the 3-bank drop targets (that the rubber ring runs around) or the t-nut removed altogether (most likely it dropped out, and was not noticed) for the spiked posts located in front of the spinner frames
additionally, I noted that the 8 metal posts (the 6 with the rubber sleeves and the 2 spiked posts with the small rubber rings) were all missing the #8 washers normally found between the playfield and the nylock nuts. the washers are important because they are used to increase the surface area to secure the posts.
missing washers = an increased probability of chewing up / compressing the surrounding wood resulting in further damage to the playfield
#30 82 days ago
detail for post # 7 was added above
hoping to trace out the lamp braid pattern tonight and knock that out tomorrow. then I will drill the counter sink holes for wood rail screw holes and work on the topside lamp sub-assemblies that are located under the cross over plastics
the 8 wood rails from this machine are pretty much beat to heck, so a trip to menards will probably in order shortly to pick out some nice lengths of oak to replace them
#31 81 days ago
I had to order the round, bare wire braid used for the lamp sockets (scot boggart has a really good assortment of tools and supplies @ pinrestore.com
hoping to have it this week to lay this down and continue
#32 80 days ago
detail for post # 8 was added above
I think that I have a couple of good source images for both halves of the playfield to show the orientations and positions of the components (by harness)
the lamp harness will also show the positions of all of the yellow zinc plated #6 x 3/8" hwh screw
#33 72 days ago
stapler arrived yesterday, air compressor connectors and hose arrived today
tomorrow or Thursday, braid should be figured out and stapled down. pics to follow
#34 71 days ago
now that I have a new portable compressor and stapler the lamp braid was laid out and stapled in place tonight. the pattern is slightly different than the original joust's due to the fact that an extra t-nut was added for each of the slings. once I have the jumper wires in place for 3 of the lamps, it will all make sense
left side
right side
entire playfield
#35 71 days ago
while making progress last night, I realized that I'm still missing a few of the correct bayonet sockets (which I had already pointed out in post #2 above. I have them on order and should have them by the weekend to continue
FYI:
when I originally ordered the 3-lead bayonet sockets, no one had the correct staple down, 3-lead part no's (077-5001-00) in stock, so I ordered 077-5006-00 instead (with the intent to cut off the laydown bracket)
marco's now has the correct part no. 077-5001-00, back in stock again
https://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=077-5001-00
ps
lamp sockets are expensive. you don't realize it until you enter all those quantities and then look at your cart
#36 70 days ago
two things that I found out, the first of which will help others
thing 1
the position of the lamp braid is critical in this area (the one in this image was stapled correctly)
you need to leave enough room for the saucer eject shield to be mounted flush to the bottom of the playfield and will also want the braid to avoid the t-nut to prevent a potential grounding issue (vinyl tubing over that section can also be used
a 3rd option is instead of jogging it to the right of the t-nut, there is enough room to run both braid lines to the left of it
thing 2
the directional guide ramps for both of the saucer eject shields were broken off, so the shields will need to be replaced
unfortunately, this part is not available in the transparent blue that was used in joust so unless the owner wants go with transparent clear, red or purple, I will have to improvise by ordering the clear version (part no. 03-9101-13) and then dye it the proper color using transparent acrylics (a huge thank you to superchicken that posted this 5 years ago
https://pinside.com/pinball/forum/topic/how-to-dye-posts-and-inserts-when-the-color-is-unobtainium
after it's dyed to the correct color, the corner will need to be removed as to not interfere with the rubber sleeved post located just above and left of the saucer
#37 70 days ago
Just want to say thank you for all thed documentation you have done. It'll make others playfield swapping so much easier!
#38 70 days ago
thanks chad
I was wondering if anyone was actually reading anything that I've been posting since no one has been chiming in. I'm guessing that no one is looking forward to the [fun] that I've been having with this one
personally, so far it's been a rewarding project and the harnesses should start getting put back in place by the end of next week (assuming that the parts that I have on order arrive on time
#39 69 days ago
I'm quietly following along with admiration. It makes me happy that there are people bringing this functional art back into the world.
#40 69 days ago
ever wonder why both sides of a joust don't ever appear to play the same way? I know that when we played, it was always a "best of 3 rounds match" where we swapped sides after the first game and loser of the 2nd game (if it wasn't a sweep) got to pick their end for the 3rd and final game
this is one of the reasons. parts on both ends were not installed the same way or at the same angles
player one side
player two side
I'm going to try and eliminate this issue with this playfield using the 36° and 126° complimentary angles on both the P1 and P2 sides
#41 68 days ago
there are 5 wire roll over switches on either side of the playfield. 4 of them are similar however a section has been cut off of 1 of them (on each side) to allow for a nearby post to be secured (these are the roll over wire switches just above the 2 pass-over drop target on both sides of the playfield
the placement of the left inlane roll over wire switch is pretty crowded, so when mounting the switch, make sure that the wire is centered so that it can actuate the switch smoothly
the 3 terminal staple down sockets arrived today, so I was able to install those along with the germanium glass diodes
here's a look at the re-routed braid near the saucer eject shields (which have been temporarily mounted with the old pieces at the aforementioned 36° angle
and finally, here is my change to help separate the harnesses (lamp and solenoid) in the areas where the wiring passes between above and below the playfield (lamps under the cross over plastics, and the trough kickout and auto plunger shooter coils)
the hole is just large enough that a 0.062 2-pin molex plug-type connector can pass through. I will show the solenoid harness connections when I have them complete
#42 65 days ago
attempting to dye the saucer eject shields today with rit dye
the first attempt with 12oz of water and about 1-2 ozs of 'rit dye more' (sapphire blue) heated to 150°F doesn't appear to do anything even after 2 hours of trying (with multiple times reheating the water). any tint that appeared to take simply floated away when rinsing the shields in a bath of clear, cool water
for the second attempt, I eliminated some of the water and added approximately 25% acetone to the solution. after approximately 30 minutes, this is showing more promise as I finally now have a light blue tint which is about halfway to where I want to be. I've reheated the water and will let the parts soak for another hour and then check again
after 30 mins with acetone added
#43 65 days ago
Quoted from j_m_:
Just curious why would the lamp sockets be equipped with Germanium glass diode?
Yves
#44 65 days ago
only the 4 controlled lamps (under the aprons) at each end have them
these are the same type of diodes used on the original playfield. all other diodes are the 4001/4004 type (black with the silver ring)
my guess is that they are being used to allow a more impactful strobing of the bulbs but maybe someone will chime in
#45 65 days ago
about 4 hours of total dyeing time got me to here which is pretty darn close. I ended up adding a total of approximately 5oz. of the rit dye plus
I just need to cut off the corner on each so that they will fit
#46 64 days ago
I dyed one extra set of the saucer eject shields if anyone wants a new set for their joust. $22 for the pair shipping in the usa
this covers the cost of the parts, dye, acetone and shipping
#47 61 days ago
work has been crazy busy this week so progress has somehow slowed
tips for re-assembly thus far
1. mount the 2 trough guides inside of the cut-outs first
2. the switch plates that sit inside the trough cut-outs are a bit tight (they will ride on the edges of the metal switch screws), but they will fit
3. check all wire connections during re-assembly. I'm finding a lot of loose wires (or wires that are simply breaking at solder points due to movement). you should have enough wire to trim off the broken ends, strip and re-attach using fresh solder after cleaning up the connections
re-attaching the switch harness
#48 60 days ago
I’ve always thought that the “gray” vinyl wrap on the joust wooden rails wasn’t very nice looking and given that the ones in this machine have seen better days I decided to make new ones from oak and stain them
I think these look much nicer (original in the front row for comparison
#49 60 days ago
the switch harness is now pretty much complete except for the 4 hunter stand-up targets, 4 flipper EOS, 4 sling and the 16 drop targets
the cable management clips make it a bit easier to see exactly how everything should be routed
the side rails will receive another coat of poly to seal them up and then will be mounted. the drop target assemblies will be mounted next before I proceed on to the lamp harness
#50 58 days ago
I forgot to order the dropdown decals for the new target faces when I ordered the drop targets (part no. 03-7773-4) from marco's awhile ago. so, I've been waiting on the order from PPS (which is stupidly expensive [4 decals @ $6.75] and you will need 4 sheets total (16 decals)]
http://www.planetarypinball.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PPA-30-1111-LM
the stickers should arrive tomorrow, so I can change all of the drops out, mount the assemblies and then reconnect the switches from the harness and proceed
ps
the following 3 suppliers are still out of stock of the drop targets, but I figured I would post the direct links to make it easier to search for those looking for them
http://www.actionpinball.com/parts.php?item=03-7773-4
http://bayareaamusements.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=TG-03-7773-4
edit:
I spoke with a representative @ marco's the other day and they DO NOT expect restock of the drop targets any time soon
Yorktown Parts and Equip
$ 50.00
$ 179.00
$ 99.00
Pinball Sales
$ 14.99
PinballElectronics.com
$ 1,199.00
$ 115.95
$ 74.00
Id Rather Play Pinball
£ 37.00
PinballToys
$ 119.99
Filament Printing
$ 7,599.00
Operation Pinball
