I’m pulling my hair out trying to isolate the cause of a JOKERZ intermittent power problem. The machine keeps blowing the F3 & F4 fuses on the auxiliary power drive board. After replacing the fuses, I can play any number of games and then randomly the two fuses pop! The fuses are in the slingshot and pop pumper circuitry.
I’ve checked and re-checked the wiring for shorts, broken insulation, bad solder joints, burned connectors, improper voltages etc. I’m confident my problem is someplace else –at least I’m hoping so! Generally speaking, the machine will blow both fuses after about 20 - 60 minutes of hard play. I’m not sure why the two completely different circuits are popping—there seems not to be any common denominator. Can anyone help with this? Any sage advice for a recommend a path to explore would be more than welcomed. I’ve been fighting this for about two months.
