(Topic ID: 201522)
Jokerz multiball problem
By Kennebunk
6 years ago
  • 10 posts
  • 5 Pinsiders participating
  • Latest reply 6 years ago by Kennebunk
#1 6 years ago
Just purchased and everything worked fine initially. After a few games started noticing longer wait times for multiball to start after locking second ball. I can hear and see relay 1 clicking on aux power board but the coil won't fire. Coil test works and at power up it kicks out balls. I removed aux power board and reseated cables. When I tried to play it worked one time then went back to not working. Tried reseating connectors again but didn't change. Any ideas?
#2 6 years ago
Lift up playfield and check the switch on lock mid left playfield.
#3 6 years ago
Hello
Wondering if possible there maybe some solder pad issues associated with those connectors that you removed and reseated. Did you by chance remove the board and do a close inspection of the solder pads that hold the pins into the board for the connectors to attach to? Maybe worth taking a closer look there and possibly reflowibg solder to those pins which would not take much time. Maybe a cheap and easy fix. Just my .02 Worth
Love the game. Doesn’t get any respect but I like it!
G
#4 6 years ago
Do the two switches register in switch test? Relay only clicks when flashing things
#5 6 years ago
Switch test works. Lock one and lock 2. I will take out board and check pins and reflow. Thanks for the suggestions!
#6 6 years ago
Odd... I hit the left flipper a few times and balls kicked out.
#7 6 years ago
Just my .02 but maybe your hitting the flipper button caused enough vibration to close/open a switch that resulted in the action you described occurring. This has happened to me before hence why I suggest
G
#8 6 years ago
Quoted from GPS:
G
I would agree if you test the switch by pushing it down with your fingers it may register but ball may not be pushing it down all the way. Check it with the ball and or take a good look at it. Just had this same type issue with rollergames ball 2 locked and game seeing it just need a little adjustment and I was back in business
#9 6 years ago
Quoted from PoBoyPinball:
Check it with two balls, the way it is when the problem manifests
#10 6 years ago
I took out the aux power board and replaced a TIP36C that was suspect. Also resoldered the relay. Put board back in and everything seems to be working tonight. Not sure which thing I did made it work. Possible bad connection. Sigh. At least it is running for now. Thank you everyone for taking the time to respond to this thread!
1,700
Little River, SC
$ 12.50
RoyGBev Pinball
$ 18.95
$ 95.00
Pinball Mod Co.
2,300
Leesburg, VA
$ 27.95
$ 5.95
The Pinball Scientist
$ 27.00
$ 54.99
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/jokerz-multiball-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
