I’m attempting to help a friend with an issue with his Jokerz. Basically the music will at times cut out. And i also notice the volume of the music relative to the sounds is very low. Adjusting the volume pot increases both music and sound, and when you get the music where you like it the sounds are way too loud.
I played a few games and for the most part the music was there. But i did notice between balls or at the end of the game the music would sometimes die, but then next game it would return.
To date - the owner had replaced the game ROM’s which did not improve the issue.
Test for the audio board and MPU sound audio test checked out.
I pulled the audio board which is unique to this game so i couldn’t use a board from any of my system 11’s. The headers had been previously reflown and one capacitor had been reworked. Aside from the flux left on the board it looked ok - but decided to clean up the pins and reflow them anyway. Reinstalled and no change. Pins looked ok as did the headers.
Caps on the board are original so i ordered new ones. Can’t hurt. I’ll do the power supply and aux power supply while i’m in there. I tested voltages at the power supply and only one i noticed that was out was the -12V which read -14.5V with everything connected. I know its unregulated but not sure if that should be closer or not...
So that’s what i know so far. While i’m waiting for some components to come in - i thought i’d ask if there was anything else i should be looking at when i get back to the game? Any tips would be appreciated!
Thanks.
