I'm very new to this pinball world, so forgive me if I don't explain correctly. I was able to pick up a Jokerz! that was in pretty rough shape but was mostly able to get everything working except for a couple of things. The main thing is that the ball will not kick out of the hole in the top left-hand side of the game. Those who know this game should know what I'm talking about. The game recognizes that the ball went in and I get the points and all the lights go off..ect, but the ball doesn't kick out. I can see that someone had previously extended the wires to the coil so I took off the tape, re-soldered the wires and re-taped (maybe I should just resoldered to the coil). I tested the coil with a meter and it seems to be ok. I believe that I traced the wire back to the J4 slot on the board (can anybody with schematics confirm?) and I noticed that the switch (in blue) goes off when the ball goes into the hole and won't shut off until I lift the PF up to get the ball out. Anybody have any ideas here? Any help would be greatly appreciated. Thanks!
