New! Dark mode!
(Topic ID: 234840)
Jokerz flipper problem
By JTreds
1 year ago
  • 16 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by GRUMPY
#1 1 year ago
Hey guys, so in the process of repairing my Jokerz! machine I decided to rebuild the flippers as they were incredibly weak. I sourced a rebuild kit and put them together but in the process of re soldering the wires back on to the coils, I'm pretty sure i incorrectly soldered the wires in the wrong places as i only took one photo and rushed a bit.
When the rebuild was done i turned on the game to test them and the moment i pressed the right flipper button i smelt something burning so i instantly switched it off. Visually the coil looks fine and nothing seems burnt but the fuse for the flippers in the backbox blew. I tried re soldering the wires again into what i believe is the correct place after doing some research and now ever time i power on the game and press the button it will instantly blow the new fuse again. Where should i start?
Also with the left flipper i rebuilt it and it worked fine but after holding it for too long in a multiball it went completely dead on me and now wont fire at all. Im pretty certain its because i didn't align the EOS switch correctly but not sure where to go now.
Any help would be much appreciated!
-JTreds
#2 1 year ago
B
#3 1 year ago
Replace the diodes on the coil you wired wrong, you might be lucky and that's all you need
#4 1 year ago
Quoted from DNO:
Agreed, and replace with correct orientation as well or you'll do it again.
Diode orientation is about halfway down the page in the link
http://homepinballrepair.com/index.php/pinball-flipper-rebuilding-how-to-fix-and-replace/
#5 1 year ago
Also, because you are experiencing potentially 2 separate issues (l and r flipper behavior is different), you may want to fix the diode flipper issue first, check for function, then work on the dead one. Better to isolate than to guess
#6 1 year ago
Quoted from MT45:
Thanks for the responses, re aligned the left flipper eos switch and now it works perfectly. As for the right flipper, i have replaced both diodes and rebuilt it properly. It is no longer blowing the fuse in the backbox but is still not firing. Progress is suppose. I took voltage readings on the right coil and flipper switch. Im not getting any voltage to the coil or through to the flipper switch. Where abouts should i go from here?
Cheers
#7 1 year ago
Check voltage to coil,connect one meter lead to ground strap other to outer terminal of coil banded side of diode,should be 50 volts
#8 1 year ago
Quoted from pintime:
Just tried that and I’m still getting nothing to the coil. What else should I check out?
#9 1 year ago
Check the blue/yellow wire on j-12 pin 4 of the aux power supply for power.
#10 1 year ago
Quoted from GRUMPY:Check the blue/yellow wire on j-12 pin 4 of the aux power supply for power.
As seen in the photo, I don’t have a blue/yellow wire on j12. The top wire is readin 5v and the other 3 are reading around 77v
#11 1 year ago
Quoted from JTreds:
That's what happens when you believe the manual. So what color wire is on the flipper coil?
#12 1 year ago
Quoted from GRUMPY:
I have a white and yellow stripe, and a blue and purple wire
#13 1 year ago
If the left flipper has power the right should also have + 50 volts they are both powered from the same source on aux driver board then fused @ f5 for right flipper and f6 for left
#14 1 year ago
Ok you have a white/yellow wire with 77 volts at the aux power supply, the white/yellow on the coil is dead. The only thing in between is the inner connect board. You need to remove the board and look on the back for a burnt trace between j5 and j8.
#15 1 year ago
Quoted from GRUMPY:
Took the board out. Sure enough a trace had burnt off. Fixed it up and it’s playing perfectly now. Thanks everyone for the help!
#16 1 year ago
Playball!
$ 54.99
$ 29.99
$ 54.99
$ 12.50
Gweem's Mods
$ 12.00
$ 2.00
Doc's Pinball Shop
Playfield - Plastics
£ 50.00
Cabinet Parts
PinballToys
$ 19.00
Sparky Pinball
Apparel - Unisex
ArcadeMade
