Ok. So I finally "fixed" the johnny glove issue I was having. I replaced the x nut, and glove switch. The glove worked very well for a couple weeks. I then started to notice the glove vibrating a bit as it was traveling back and forth.
Shortly after those symptoms started the glove will no longer move. The x screw rotates and the glove mech does not move. I am assuming the x nut has stripped out again.
My question is what would have caused the nut to strip out so quickly? What can I do to remedy the situation next time?
Should I lubricate the screw? Yes. I realize what I said
Anyone else ever run into this problem?
