(Topic ID: 185795)
Johnny Mnemonic Williams - More fun with the hand! Stumped!
By puck
2 years ago
  • 23 posts
  • 8 Pinsiders participating
  • Latest reply 2 years ago by puck
There have been 8 images uploaded to this topic. (View topic image gallery).
#1 2 years ago
Totally stumped.
• hand was working flawlessly until I had a pin-night and the hand caught a wire in the back and decided to wrap it around the opto board.
• now I am getting hand self test failed.
• No movement at all, but hand moves easily manually.
• switches all work
• replaced hand opto boards
• re-flowed the board that connects to the hand
• new magnet and wiring harness
I welcome ANY ideas on what to test next. Have tools will try almost anything.
#2 2 years ago
The wire that decided to fish itself into the opto board YIKES
Looks good to me!
#3 2 years ago
Probably something got pulled loose. If the switches are all working it sounds like power to the motors there are two as I recall so trace back to common power supply source if both are not working. Double check all connections with too, sometimes something passes the visual test but doesn't work.
#4 2 years ago
Well.. D19 & D21 are now locked on. So looks like I have bigger problems. Yikes!
#5 2 years ago
U20 and U15 were causing it not to boot... hurm.
What should I measure at the motors? Checked and re-seated all connectors. Same deal. Also I think I have a bad chip in my U20 as the coin door buttons are only half working. Might have a row out.
#7 2 years ago
Thanks Axl, no fix in there for me sadly.
#8 2 years ago
Was it a switch wire that pulled loose? If the voltage from the motor got in the switch harness you have a cpu problem.
#9 2 years ago
Quoted from WeirPinball:
It wasn't in the switch cables... and the wire that it pulled didn't disconnect, got lucky I guess. That said I'll see if I can borrow another CPU board from someone and test. Good idea. Thanks Weir Pinball!
#10 2 years ago
Perhaps somebody more versed can help me with this. J107 according to this image should putting out 20 V. Is this continuous or only when the CPU board tells it to? As of right now the red and white wire is not putting out anything. IMG_9728 (resized).JPG
If it's continuous then I definitely have a power issue. Otherwise I have a CPU board switch matrix issue
#11 2 years ago
I think you maybe omitting some helpful info.....? So the wire got caught on the rod and then what? Did it blow any fuses? Did the game reset? Did the hand suddenly stop? I don't think anything like you're describing would have happened with the wire getting pulled. So the problem is elsewhere, first off go in the switch test and then the coil test...is everything else working?
#12 2 years ago
Quoted from puck:
Continuous.
#13 2 years ago
Totally.. here is some that info
Hand stopped working I discovered weeks later when I was playing the game.
Nope, but it did blow up the hand opto board.
Did the game reset?
Nope
Yep!
Switch test is good. It was like there was no power from the board.
Thanks everyone for the help!
#14 2 years ago
Thanks! I'll pull the board and inspect / test
#15 2 years ago
Quoted from puck:
Which one?
#16 2 years ago
If that wire took a lot of abuse, it may have sheared off inside the insulation. Make sure you have continuity when probing both ends and wiggling it around.
Have you determined what that wire is? Power? Ground? Sounds like it's not a switch connection.
Also- might be a dumb question, but are the motors turning on without driving the hand anywhere?
#17 2 years ago
Quoted from Law:
The motors are not turning on or moving at all. The wire that was stretched was a flasher wire and a check for continuity so I know it didn't do anything bad there. Still stumped welcome any next things to check.
#18 2 years ago
The plot thickens
TP1 = 15
Tp2 = 5v
TP3 = 12
TP4 = 0
TP7 = 0
TP6 = 90 then drops to 75
#19 2 years ago
Testing continuity between U1 / U2 I noticed this. Yikes but.... J104-5 is listed as N/C so WTF now I am confused is this related or perhaps I just found an unrelated issue.
#20 2 years ago
Um, you did see that trace that's cooked on J104-5..right?
#21 2 years ago
That's one of the traces to bridge rectifier BR.4
1st suspect would be BR.4
#22 2 years ago
How big is the fuse for F-111?
#23 2 years ago
Quoted from GRUMPY:
5A SB and installed. Fuse is good.
$ 47.00
$ 129.00
LED OCD
Gweem's Mods
KAHR.US Circuits
PinSound
Portland, OR
Cleveland, OH
Colts Neck , NJ
$ 29.00
$ 22.50
$ 11.95
$ 50.00
$ 219.99
$ 40.00
Pin Mods
$ 16.00
