Ok so figured I'd take a couple of pictures demonstrating the easy way to change bulbs in the JM grid.
So - you just pull the playfield forward. I recommend taking the top ramp off to get it out of the way. (3 nuts and a plug).
Then unplug the two white connectors and the third that connects to the solenoid as pictured here.
Next - you use a nutdriver to unscrew the two nuts attached to the threaded studs pictured on the back of the matrix assembly. (These threaded studs protrude through the back wall and you unscrew them from behind.)
Really easy to pull out the entire unit. Then just turn it over.
I bought a bag of RED Bendy's from Comet (on sale for $18.75/25 pcs).
http://www.cometpinball.com/product-p/25-pack-flex.htm?1=1&CartID=0
Bendy's are perfect for the Grid because they reach farther and allow you to point them perfectly for maximum illuminaton of the matrix buttons above them.
This first picture shows you how far away from the incandescent bulbs the buttons are.
This picture demonstrates why bendy's are so valuable in the grid - because not all of the holes are fully aligned (and open) so without a bendy you won't fully illuminate the button from the top!
Happy Playing!
