Nice job!
Quoted from jazc4:Getting closer to finishing my restoration. Here’s a few before and afters.
[quoted image][quoted image][quoted image][quoted image][quoted image]
So where are we getting the correct cabinet decals these days? Lots of talk about sub-quality ones in this thread. On my to-do list.
Anyone looking to sell their Johnny Mnemonic? Putting out feelers for those in the DC area, north or south of there (VA, DE, MD, PA, NC, WV). Thanks!
Quoted from MG7322:So where are we getting the correct cabinet decals these days? Lots of talk about sub-quality ones in this thread. On my to-do list.
Quoted from GraniteStatePin:So I just rebuilt my glove a few months ago, couple 100 games, lets say 500 to over compensate, my X nut on the glove (larger nut for left and right movement) is COMPLETELY worn out. Metal dust/shavings everywhere in back. Almost wore right through the side of the nut.
Glove was working mint since rebuild, very quiet and responsive. Anybody else have this happen? I used super lube on the rod and everything moved smooth with minimal resistance. Are these replacement nuts just not as good as originals?
Were you using the thick super lube? I'm sorry this sounds disheartening.
Quoted from supermoot:Were you using the thick super lube? I'm sorry this sounds disheartening.
I can't remember if it's the synthetic or silicone Super Lube but either way it is rather thin.
I haven't pulled it apart yet to really give it a close look.
I'm actually only familiar with the super thin stuff for spinners. It looks like it the other kinds are thick an greasy enough. I've only used the teflon goop from that awesome guide. Super web grease.
If you have Facebook.. send this guy a PM about JM plastics.
Quoted from PoMC:Anyone have or know where to buy in the USA, this plastic?
https://pinside.com/pinball/forum/topic/johnny-mnemonic-is-there-an-owners-club-yet/page/77#post-6752161
Quoted from Stebel:I have the CPR panel. It is not a direct replacement for the black plastic panel. This panel is larger and sticks to the H Chanel as well as the lower c channel. With double sided tape.
The panel also has a cut out for the dmd. You leave your old black panel in place and the clear part of that panel covers the dmd.
For this game they should have made it smaller and made it a direct replacement for the boring black panel. With no cut out.
I would like to amend my comment on the CPR speaker panel replacement. The panel is a DIRECT replacement for the factory black speaker panel plastic.
I had one of the first ones every made by CPR and the dimensions were to a wpc95 panel, which is why my original was too big.
My new CPR speaker panel plastic is perfect. I event cut the panel wood to light up "The Ultimate Hard Drive" red portion.
cpr panel (resized).jpegQuoted from Stebel:I would like to amend my comment on the CPR speaker panel replacement. The panel is a DIRECT replacement for the factory black speaker panel plastic.
My new CPR speaker panel plastic is perfect. I event cut the panel wood to light up "The Ultimate Hard Drive" red portion.[quoted image]
Twins!
E37BA127-DF64-4F80-93B0-A87E014248C0 (resized).jpegQuoted from jazc4:Any of you willing to sell your old speaker cover? My JM didn't come with a speaker panel. I had an extra RS panel but still need the JM panel skin. Thanks. Stebel Power87 Luke
sure! Pm me
My speaker cover is extremely scratched up hence why it was replaced. It really would not be worth using.
Has someone created a new GB spinner sticker to correct the Gb error? Fairly new here and haven't gone through all previous posts. Was this just a mistake from Williams?
Quoted from dnaman:Has someone created a new GB spinner sticker to correct the Gb error? Fairly new here and haven't gone through all previous posts. Was this just a mistake from Williams?
What is the error?
Quoted from Stebel:What is the error?
In this context, the lower case 'b' is shorthand for 'bits', while an uppercase 'B', which is obviously what they meant, is shorthand for 'bytes'.
320 Gb is only 40 GB; still an impressive amount of storage capacity for 1995.
decal says 120Gb (Gigabit) instead of of 120 GB (GigaByte)
120Gb (resized).png Added 13 months ago:Oops, yes 320GB. I typed it all and then added the pic.
Quoted from dnaman:decal says 120Gb (Gigabit) instead of of 120 GB (GigaByte)[quoted image]
320 not 120
I got the playfield in the cabinet and apron on it. Door is being powder coated. Next is to get the remaining boards installed and powder coat the remaining armor. The. I can fire it up for testing. Also these are the decals from Pinball Decals EU.
14FF3B6B-8F86-4FFB-A52F-D49884C0D813 (resized).jpeg30FF6269-17E1-4AE6-802C-F2C3004E8F28 (resized).jpegQuoted from Power87:Try doing a factory reset.
Worked for me when i rebuilt the hand
Thank you, I did read that and I did try it, to no avail.
I was thinking it was a motor issue, but yesterday my friend got it to move a little
Added ColorDMD LED that I had not being used; new mirror blades I had for year; LED OCD board for the insert LEDs and a shaker kit also not being used for a few years.
Wow! Great additions to a fun flowing game.
Anyone else make their game harder? I removed the adjustable, left outlane post completely. Right outlane post is in the middle position, didn't change that.
Extra ball memory is off. You need to collect the extra ball before draining. I prefer this in general with all my games because it gives the extra ball a sense of urgency. Otherwise if you know you can drain because it's lit on your next ball, that's not fun.
Mnemonic Recovery, left outlane ball save memory is off. It's lit for ball one, but every ball after you have to re-lite the ball save. Does not carry over to the next ball, every ball starts with it off.
Quoted from cricrow:Thank you, I did read that and I did try it, to no avail.
It’s probably one of the optos that the opto wheel passes through. Make sure you can physically spin each wheel with your hand and then it’s not caught up somewhere. then go into switch test mode and see if both Optos on each axis is registering
Quoted from PoMC:Anyone else make their game harder? I removed the adjustable, left outlane post completely. Right outlane post is in the middle position, didn't change that.
Those are all excellent changes. I have seen many JM missing the left outlane metal post.
Before the changes how often where you reaching PowerDown?
How steep do you have your game pitched?
Like all my games, my feet are all the way extended, feet are sitting on top of 2 floor sliders on each side and a 1/2 inch rubber shim on each side. Front feet are removed.
Game plays so freaking fast you are lucky to get 1 minute ball times. (Outer orbit shot can sometimes throw the ball over your flippers on the way back)
Quoted from Don44:It’s probably one of the optos that the opto wheel passes through. Make sure you can physically spin each wheel with your hand and then it’s not caught up somewhere. then go into switch test mode and see if both Optos on each axis is registering
Both opto’s are working, tried to help him out yesterday, but not familiar with Johnny,
But more than happy to go over and help cricrow with some type of direction
Quoted from Luke_Nukem:How steep do you have your game pitched?
Haven't reached it yet. I started ownership with the post removed and did not reinstall it. Had it lit twice at least though.
Quoted from Power87:Do you have the glove turned on or off in settings..
Just a thought lol you never know.
It is turned on and the the error message is x no progress
X home switch error
Quoted from cricrow:It is turned on and the the error message is x no progress
X home switch error
Did you try reflowing the solder to the motor? Maybe there is a cold solder joint and it isn't getting a good connection.
It looks great, that’s an insane amount of work to get done in 8 1/2 hours. That would’ve taken me a whole weekend
Quoted from Don44:It looks great, that’s an insane amount of work to get done in 8 1/2 hours. That would’ve taken me a whole weekend
Thank you! My previous post's pictures got out of whack so reposting it here:
Full JM teardown and build log:
1D069555-3885-49F7-A975-E65901F1D72D (resized).jpeg 346AB3E9-899E-4444-A728-942094A65BC0 (resized).jpeg E3EEA492-C8C1-4717-87E8-CEE3DA289436 (resized).jpeg 9997153B-7A67-4D78-AD68-818F098B6077 (resized).jpeg
Started the full tear down around 2pm EST. Just wrapped up around 10:30pm.
- Full removal of all ramps, plastics, posts, rubbers, mechs.
- Removed Mylar from pop bumper area using a can of compressed air turned upside down
D85226DF-4E3A-4DD5-AB18-6C5D77728641 (resized).jpeg F8A9DBB2-E1D8-4D79-8B80-C48513EC09EE (resized).jpeg 9644E3DE-00C3-40FA-BA9E-DBAE88AF1D1A (resized).jpeg
I’ve been on a streak removing Mylar from all my games without pulling up any artwork. The key thing is to let the freezing solution do the cutting / lifting. Never pull! It will lift on its own as long as you are sweeping left to right underneath the piece of mylar.
***This is THE best and quickest most efficient way to remove adhesive left from factory Mylar***
Lay down a paper towel flat over your adhesive area… Soak it completely with 90% alcohol…. Let it sit for atleast 10 minutes..
85C5D85B-EDBD-4EED-824E-2699C7101CF9 (resized).jpeg 7E15004B-E122-4D9F-AA53-DEF93993B288 (resized).jpeg
Come back and rub with a clean microfiber and it will pile up all the adhesive… mist the area as you wipe away as the adhesive will pile up under your towel and basically rub back into the playfield.. keeping it wet will keep it lifted
I’ve spent over an hour in the past trying to remove the mylars adhesive often becoming tougher than pulling the Mylar up.. I’ve tried Goo gone, brake cleaner, heat gun, scotch pads, rubbing alcohol, nail polish remover…. Nothing beats the above method.
936FAF99-18DD-4D6D-857D-F3D106C86A2D (resized).jpeg 6C553D96-669A-4FB8-8558-B71E336EE224 (resized).jpeg
- Installed all new blue posts and rubbers
- Rebuilt pop bumpers completely, including new skirts, bodies, spoons, switches, tops, 555 light fixtures, springs, plungers, and plates all in translucent blue
- Wet sanded all ball guides with 2000 grit and 90% alcohol
- Waxed playfield thoroughly
- Flame polished every single plastic and ramp top and bottom
A4816B9B-AB45-4822-B367-AF9A8518B695 (resized).jpeg D86BB7A8-032E-4E93-B3B0-C2653D43707E (resized).jpeg
- Rebuilt glove with new X and Y nuts, cleaned out both gear boxes ridding machine of that horrific screech when moving
- Rebuilt flippers with new armatures, sleeves, springs, flipper bushings
4BDA7808-1A67-478C-B90A-B504C22166F3 (resized).jpeg DE54869F-9B77-403C-91FD-52BA1EE91750 (resized).jpeg 7D07002B-1DE2-4BFB-8C3C-F0AA82D44F5C (resized).jpeg AA079A06-CDDC-4B89-A634-E3DF35FC9A98 (resized).jpeg
- Installed Cointaker Ultra brite purple LEDs in GI
- Installed Comet LED strips and 8 SMD pads all over the game, including back box, DMD glare guard to light up speaker panel, above the playfield in the back
- Installed Pinsound plus board running my own custom cyber / epic music and sounds.
Board was was repaired by Pinsound at TPF to fix “Engine error” that was randomly popping up leaving game with no audio
- Dialed everything in, game plays Too fast, but I love that! I had the glass off while tweaking some things, two loops around the outer orbit I tried to stop the ball with a flipper in the upwards position hit so hard and fast the ball literally flew outside of the machine and on to the floor
Thanks for reading!
Joined!
Straight trade for my DE Jurassic Park.
Dirty but playfield is in excellent condition, everything seems to work but needs a thorough cleaning.
Cabinet/side arts are worn but nothing extraordinary.
Excited to get to know this game!
2E6BF1C0-53B1-45E8-B295-8D60E5BB1274 (resized).jpeg54705A10-066F-4449-AC00-AB36F44F3D4F (resized).jpeg89A963FE-4F40-4681-8F38-38386D91C3F9 (resized).jpegA3B2FF62-4680-4E9D-943E-1201251A74F7 (resized).jpegBDAE5874-DED7-4139-9CEB-3631B1332CCE (resized).jpegCA64A322-A51B-4B85-8259-4F2830B18886 (resized).jpegD5EDF928-E275-4F9E-98AF-5D80F51CC2F1 (resized).jpegEF5292D2-CFBC-466A-80EC-32144658B30A (resized).jpeg
Quoted from allsportdvd:Has anyone ever tried to recreate the topper in this pic from the Pinball Compendium?
I have the promo board shown on the front but not the side pieces
May very well be the only topper larger than DE Jurassic Park.
Getting closer to bringing Johnny online. Thanks to Luke_Nukem for supplying me with the missing speaker panel skin.
A063F7CF-3736-4DCA-8BE4-AACCC2986073 (resized).jpegQuoted from allsportdvd:Has anyone ever tried to recreate the topper in this pic from the Pinball Compendium?
Please post pics of the promo board.
Quoted from Stebel:Please post pics of the promo board.
Here is a pic, it’s the width of the backbox so perfect fit for a topper
Except pinside isn’t letting me upload a pic
Quoted from allsportdvd:It finally uploaded!
Anyone have one of these promo posters for sale?
This page was printed from https://pinside.com/pinball/forum/topic/johnny-mnemonic-is-there-an-owners-club-yet/page/84 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
