(Topic ID: 154951)
Johnny Mnemonic: Intermittent issue with ball launch
By atariaction
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by atariaction
#1 3 years ago
Just put it on location. Owner says the ball kicks out to the shooter lane but occasionally the launch button will not send the ball up. He said he hits the side of the cabinet and that solves the problem. I tested the shooter lane switch in switch test thoroughly and it seems to work perfectly. I also played a bunch of games and it never happened to me of course. Diode and wires on that switch all look and feel attached well.
What else should I be looking at? Possible switch matrix issue? I was not thinking so since all my test games all seemed to work just fine.
#2 3 years ago
How about ball launcher switch test?
Sometimes with intermittent switches issues its best to just replace the switch
#3 3 years ago
I did not test ball launch in switch test but I will now. I just tested it in normal game play and it worked perfectly every time for me.
#4 3 years ago
Double check the wires on the coil lugs. See if they're loose. Give 'em a little tug.
#5 3 years ago
Make sure you're testing the shooter lane switch with an actual ball and not your finger, roll it up and down a couple times and make sure it's not getting stuck in a divot above the switch or something.
#6 3 years ago
Will do
$ 47.00
$ 399.95
Pin Stadium Pinball LEDs
$ 99.00
Pinball Sales
