Well, under a week in, and I already have the exact same identical issue that I did back in 2012.
So, I was putting LEDs in the underside of JM, and I played a game. The ball got stuck on the diverter near the hand, so I waited for the machine to find the ball. That was when I noticed that hand went over to the matrix and STAYED over the matrix; it never came back on its own until later in the game.
Then the dreaded problem began. The ball started a mode, and the glove missed the ball. You could see it pop up and down up and down up and down, but the hand looked to be off center from where it was trying to catch the ball. Then I saw the credit dot appear mid-game.
"Ball in hand F5 Error" - that looks awfully familiar (2012).
I manually tripped the switch in the magnet, and the dot went away. Figured "whew" that was close, and for a bit the hand behaved - until it started missing the ball again. And something else I've noticed, when the hand goes forward to drop the ball into the pop bumpers, it DOES NOT return back to the starting position.
Now it's a bit of a crapshoot as to what the hand is going to do. I've noticed when it self-calibrates, the hand will zig zag back and forth left to right 7 or 8 times before it seems to just quit trying, and other times it'll get right into position, but then there's an issue every game I play.
Help . I don't really know what to do to diagnose this behavior. In the relative little bit of searching I've done, I haven't seen anyone else say they have this problem.
I'll continue updating this thread accordingly as more problems/issues occur as right now the hand is all over the place with errors.
