Like many, I am having trouble with the hand on my Johhny Mnemonic machine.
I ran the hand test with the following results:
Self test: Passed
Home test: Passed
Move test: Worked fine to start but then failed. I was able to move the hand to all (4) of the travel corners but as I went back and forth a few more times it failed. I did notice that when the hand moved all the way forward it seemed to want to continue to travel just a bit which caused the guide rod to bow slightly until I moved the hand back.
Auto Run test: The hand picked up the ball and then started to move but dropped the ball before it even got close to the matrix. It picked up the next ball but then did not move or drip the ball. While still holding the first ball it picked up the second ball and the third ball but did not move and did not drop any of the balls.
The problem seems to be intermittent as shown during the tests.
Can anyone offer some suggestions on what to check and/or replace?
