(Topic ID: 224963)
Joe Balcer confirms Oktoberfest as American Pinball's next pin.
By PismoArcade
2 years ago
  • 4,672 posts
  • 436 Pinsiders participating
  • Latest reply 29 minutes ago by Pyromedic
  • Topic is favorited by 72 Pinsiders
There have been 515 images uploaded to this topic. (View topic image gallery).
There are 4672 posts in this topic. You are on page 93 of 94.
#4601 51 days ago
Quoted from GrandFireball1:
After you get to FM the first time, you will have to play every mode again to reach FM a 2nd time, regardless if you completed the mode prior
ok, that's now clear
and pity, as it would have been nice to go back to FM as i've exposed... i dont see lots of guys to be able to do all the modes twice !?
may be an idea for a future update (yes i know Joe, you have already a lot to check )
#4602 51 days ago
Not sure if it’s what you’re asking, but once you’ve played the other 13 tents, Flipper Meister is qualified, but you’re not obliged to start it... you can instead play other tents to try to win them for improved scoring in both bonus and Flipper Meister. You might also choose to defer Flipper Meister if you want to collect some Pin Wiz Pale Ale steins before playing FM. You’re only forced to play FM if you’ve already won all 13 other tents.
Regardless, yes, once you play FM, status for all the tents resets and you can play them fresh. (Of course, at this point you almost certainly have a bunch of steins and a bunch of ducks, so the tents should be significantly more valuable the second time through.)
#4603 51 days ago
Quoted from Ferret:
heu... no !
may be i must retry without the glass and see by myself, but as explained above, after having played FM, the only tents available were the 3 ones i didnt fully completed... all the others (which than i did completed before FM) were NOT available
will look more at this next time Joe
Mic
#4604 51 days ago
ok, just tried without the glass, it worked as you've said, all tents available again after FM !!! (and now i understand why you firstly not understand me ! lol)
than, or i'm fool (to be honest, my wife has a doubt) !? or i was drunk (no chance) ! or i get a bug... ?
this game should be in the logs, as usual will send the file in PM
#4605 51 days ago
Quoted from RipleYYY:
if you 'think' there was a bug, but then testing it works as expected, and you can't replicate it, it is probably not a bug, and given a log file can have tens of thousands of lines, we typically are not going to spend time looking for a needle in haystack, when there is no reason to think there is even a needle to fine.
#4606 51 days ago
Quoted from rosh:
no worry Josh
i will be more attentive next time (if this happends again !?)
#4607 50 days ago
I never played a game I own without glass. I prefer playing normally and discover new things
day after day
#4608 49 days ago
Quoted from yoyokopter:
Hi , thanks for the explain Rosh , I play the SOBER mode (2h19min) , but there is no insert light on the playfield
Quoted from rosh:
if you can't see the lights you are so far from being sober, they don't matter
I've seen this on rare occasion, but have not been able to replicate it, to be able to figure out what causes it.
got that one too few days ago, can't help about how/why it happends...
#4609 49 days ago
Quoted from pimseb:
day after day
Hi , RipleYYY don't play without glass to discover the pinball but to simulate a real bug on the code , is not need play without glass to make the end of on pinball
#4610 49 days ago
Yes this bug is real , and on the vidéo you can see other bug , exemple , the insert "shoot again" blinking when you use the flipper ... and I look it's not a bad contact on the LED
#4611 48 days ago
I've reported this bug back in February 2020. I received an answer from Barry Engler by email :
"I was able to replicate this problem on my machine, it is a bug and I will let software know.If they can get things sorted out quickly, I am sure it will be in the next release."
Unfortunately there hasn't been a software update since then and I'm still waiting for this bug to be fixed.
#4612 48 days ago
Quoted from pimseb:
I did that fix back in February, it was also impacting HW, and it will be in the next release. Speaking of which, with the latest HW code released, I've started doing some work on Houdini and Ferret has started work on some Oktoberfest fixes and improvements.
#4613 48 days ago
Quoted from rosh:
We totally LOVE Octoberfest! at our house. If there is none thing that I might like see changed, just as a suggestion, is the very generic Ball Save in that giant yellow balloon circle.
Oh, and Shayley (my 5 year old Pinball addict) says its to hard to make the little doggie go down the slide!
#4614 48 days ago
Quoted from Pyromedic:
Settings > Oktoberfest > Sky Slide Drop Target Time
#4615 46 days ago
Arrived and set up today! I'm in love! For maybe 2 minutes I didn't have the balls to press start, I just stared blindly at all the lights with no clue where to go first but within 1 or maybe 2 games I knew what was what and boom, we just clicked like the best first date ever! I can barely type my forearms are blown up! (I'm also a few sheets to the wind!!).
One tiny tech question with a simple fix I'm hoping, is the audio output in stereo? The amp is great and loving being able to adjust the audio to suit my tastes but the 3.5mm jack into the amp isn't being recieved very well, it sort of has to be not quite clicked in all the way for all the speakers and cab speaker to work. The amp has an unused left and right rca imput so can I redirect the audio into the amp using a simple £3 converter like this?
https://www.ebay.co.uk/itm/NEW-20CM-STEREO-FEMALE-3-5MM-JACK-TO-2X-RCA-PHONO-MALE/150432043057?epid=1788255232&hash=item230672d031:g:OtoAAOxyi-ZTZNbO
Thanks for any advice on this and congrats to all who played a part in creating this masterpiece! Thank you, thank you, thank you! Sorry, Danke Schoen!!
#4616 46 days ago
Has anyone added spotlights to the lower part of playfield?
#4617 46 days ago
Quoted from JonCrox:
https://www.american-pinball.com/support/service/ Check with American Pinball before you try anything.
#4618 44 days ago
Give it a try. It’s cheap enough.
I know people plug external subs directly into the amp using the rca plugs.
#4619 44 days ago
Quoted from 27dnast:
I guess not...? Was hoping to confirm what V bulb I should use?
#4620 43 days ago
The GI is full RGB on OKT so you'd have to find a different power source than just one of the GI bulbs, maybe the coin slot bulbs because I believe those are still 555 incandescent (they are on Houdini anyway) but I'm not sure what they are powering them off of, maybe the 5VDC. There is a 12VDC supply you might be able to pull off of somewhere as well.
#4621 43 days ago
Happy International Bier day!
Prost!
#4622 43 days ago
Prost!
3 and its multi-beer !
#4623 43 days ago
Hello,
I'm still enjoying my Oktoberfest pinball machine but I'm now trying to understand how steins are affecting the game. I easilly understand how some of them work ; like 1 "not'n roht'n" stein will give two TENT letters instead of one when the ball goes through inlanes/outlanes.
It seems that some steins don't boost anything. For example "Ish Pale Ale" gives the feature "easier to collect steins" but the ball must always hit the bar entry 2 times to make it open. Even if I own 2 or 3 "Ish Pale Ale" steins. Shouldn't the bar be permanently open with 3 steins ?
Second example : "Sloshed Rosh Lager" : easier to collect OKTOBERFEST letters. Even with 3 of this steins in my collection, 1 target lits only one letter. I thought with 3 steins one shot would lit 3 or 4 letters at the same time.
Is it a normal behaviour or am I misising something ?
Thank you
#4624 42 days ago
Sloshed Rosh lager gives “neighbors”, so with one stein if you hit an okto letter already lit, it gives a neighbor, two steins it will look two neighbors out looking for an unlit letter, etc. It also increases scoring in looper.
Ish pale ale makes it so you need fewer hits to open bar, but settings can also be a factor in how many hits are needed. It will never just stay open forever.
#4625 42 days ago
Quoted from rosh:
Does this continue to work this way during the Ring Toss tent or Corkscrew Multiball? Or does it go back to must hit unlit
#4626 42 days ago
Quoted from Hop-Pac:
Only applies to Oktoberfest letter collecting towards locks
#4627 36 days ago
Hello Oktoberfest fans!
We will soon be starting the next round of beta testing for the upcoming Oktoberfest code update, and we're seeking people who might be interested in testing.
We ask that beta testers be willing to put in some solid hours play-testing over the next couple weeks, and be willing to send in logs and reasonably detailed notes of any problems you find with the test code. Beta test code may have problems, up to and including crashing the game, so putting beta code on location (public/revenue-generating) games is not recommended.
If you'd be interested in participating, please send me a DM with your name and e-mail address. Please do so even if you have previously beta tested Oktoberfest or other American Pinball games. Note that to keep things manageable, not all respondents are guaranteed to be added to the beta program.
#4628 35 days ago
when you know you have no luck (even if this game finish at 34M) :
left outlane while SOBER lit
play it & did complete it, with a last letter touched on side targets, than while Inga was saying "yes you are sober", ball cross the playfield and out in the opposite outlane...
oh dear ... looooooooooooool that's why we like playing pinball
#4629 35 days ago
Sometimes the ball is just hell bent on draining. My usual nemesis is the brilliant slap-save that rescues a SDTM ball, but then ricochets a couple times and slams out an outlane. As you say, that's why we love (and occasionally hate) pinball.
#4630 35 days ago
I'd love to test but don't have enough time to put into it. Thank you for pushing forward on a great game. It will NEVER leave my collection. Too close to my family roots...love everything about it including the art. Can I get a monkey translite???
#4631 32 days ago
Anybody have any idea what happened here? rosh, ferret. My game went nuts. After player one drained, player two is up and the game just kept shooting balls by itself. This lasted for a full 2 minutes before I turned it off. Then I turned it back on and adjusted a few settings (tent completion changes) and started a game. Now I have Thor's Hammer Stein instead of Castrated Monkey.
#4632 32 days ago
not sure what that was, but you can send the log to ferret@american-pinball.com
family friendly OFF = Castrated Monkey vs family friendly ON = Thors' Hammer
#4633 32 days ago
Quoted from rosh:
Ok. That's one of the settings I changed.
No idea how to send logs
#4634 32 days ago
Page 45 in the manual. Send the log to ferret@american-pinball.com
#4635 32 days ago
Quoted from LTG:
Thanks LTG
I don't think I have the right manual. I'll download the correct one
#4636 29 days ago
Does anyone have a solution for this? Happens constantly, I may have to bend a plastic piece from the sign to get it to stay out.
#4637 29 days ago
Quoted from Viggin900:
Sorry - I can't help as I don't have an Oktoberfest yet. Got a question for you though - what did you use for the striped hex post sleeves on your game? They add a nice touch!
#4638 29 days ago
Does it fly off the wireform and lodge there ? If so I'd see if the side by the stuck ball can be raised a little altering the path of the ball. If it's coming off the plastic ramp early and going there, the two screws holding the clear plastic guard to the ramp, I'd add something to that area so it extends to the barrel farther. Plastic or something.
#4639 29 days ago
I don't have the game to check. But any chance the steel wall needs to be bent out a little, making the gap to the barrel a little wider? See the red arrows.
#4640 29 days ago
Happens on mine too but not very frequently. Probably 1 out of 10 games or so I'll get one stuck there.
#4641 29 days ago
https://pinside.com/pinball/forum/topic/oktoberfest-owners-10-/page/10#post-5793483
#4642 29 days ago
Quoted from Tuna_Delight:
Viggin900 made them:
https://pinside.com/pinball/forum/topic/free-oktoberfest-mod-maypole-and-pennants#post-5132582
#4643 29 days ago
Thanks! I have the flipper power adjusted but still flies off. I'm going to bend that metal plate next.
#4644 26 days ago
Try bending out the guide to the lock entry a bit.
#4645 26 days ago
yes. Take all the pinballs out put them on a flat surface and see if they are sticking together. My Oktoberfest was driving me nuts early on with b******* ball saves and acting all sorts of stupid. Got a new trough and was still having issues. Took the balls out and they were all sticking to each other. They don't roll down to the bottom of the trough like they should when they're magnetized. One of my buddies was having issues with balls magnetizing on a different game when I mentioned the symptoms to him he said pull the balls out and take a look. Sure as shit they were all clumped together. I feel your pain as it was a maddening problem and it also has intermittent.
#4646 26 days ago
Good point, swainer80. For reasons that I don't understand, certain pinballs are MUCH more prone to being magnetized than others. (Back when "super shiny" balls debuted -- 20+ years ago? -- they were known to be disastrous in games that heavily used magnets, like Twilight Zone.) Of course, Oktoberfest uses its four magnets a lot, so balls that get magnetized easily will become problematic.
I suppose I should figure out a clever algorithm to determine if trough problems might be caused by magnetized balls, and display an operator warning.
#4647 26 days ago
The non stop balls were happening to my new okf and Dave of API was supplying me with new pcb’s in search of a solution. Although it doesn’t happen nearly as often as it was before the board replacements it will occasionally rear its ugly head without warning. If a ball is sticking in the trough due to magnetic attraction wouldn’t that prevent it from moving into the launch position and just cause a backup in the trough instead of an endless regurgitation of balls?
#4648 26 days ago
Not necessarily. That presumes that the entire chain of balls is sticking one short of the expected position. That may be possible. It's also possible for the balls to be stuck together in one or more clumps, each of which may or may not roll fully to where the trough optos expect the balls to be. And then those balls may shift around at weird times. Basically a series of pseudo-random (unpredictable) things that can lead to problems that "occasionally rear its ugly head without warning", as you note.
I'm not saying that everyone who has unexpected problems with the trough, crazy ball saves, etc can 100% blame magnetized balls. Tons of issues -- mechanical, electrical, software -- could be involved, and if you're having trouble, the American Pinball team is standing by to help you. But if you are experiencing trough-related problems, by all means, please pull out the balls and test them to see if they're magnetized. If they are (even a little bit!), it is highly recommended to switch them out for balls that aren't magnetized, and hopefully that simple solution will resolve your issue.
#4649 26 days ago
Quoted from Filimurz:
Logs can often shed light on this, so keep a USB handy, with no game code on it, and if this never ending serving of balls occurs, just grab the USB, stick into the USB cable in the cabinet (inside coin door) and send us what gets put on it.
#4650 25 days ago
Ferret, have ordered a new set of balls....since I could only find steel ones I presume they are subject to becoming magnetized, too??
Rosh, thanks, I will keep a blank thumb drive at the ready for the next episode of “Balls to the Wall”
$ 7,395.00
Great American Pinball
$ 7,395.00
Operation Pinball
$ 7,399.00
Nitro Pinball Shop
$ 279.95
Pin Stadium Pinball Mods
$ 279.95
$ 7,395.00
Classic Game Rooms
$ 7,395.00
Gulf Coast Pinball, LLC
