New! Dark mode!
(Topic ID: 244666)
JJPOTC Treasure Chest Open/Close mod, now working!
By pinballj
1 year ago
  • 1,297 posts
  • 122 Pinsiders participating
  • Latest reply 15 days ago by Betelgeuse
  • Topic is favorited by 90 Pinsiders
There have been 216 images uploaded to this topic. (View topic image gallery).
There are 1297 posts in this topic. You are on page 6 of 26.
#251 1 year ago
Ordered placed! One of the best mods ever! Looking forward to these shipping in several weeks!
#252 1 year ago
Also ordered!! Looking forward to it!!
#253 1 year ago
Man I can not wait to get this in my game. So I actually have the majority of the parts so going to build my own... one key part I am still a little unsure on is the chest Bracket(s).
It would appear the original bracket on the trunk lid was modified, and another bracket was added and bent to a 90?
#254 1 year ago
Thats a newly manufacturer lid bracket, looks like original but the lip needs to be on the other side .
Bending the existing lip cold the other way its now wil result in a fracture if you dont heat it on the bend line
#255 1 year ago
Quoted from steigerpijp:
Right
This is a newly made part.
I did not want to destroy the original part,
think also that it would break with cold bending.
#256 1 year ago
the bracket may have been made but the main part in that picture I am pretty sure is the original trunk bracket?
i have a blow torch and that is how i would bend it... wonder if the bracket would be strong enough if 3D printed at high density.
#257 1 year ago
If anyone wants the 3d printed part only they are listed now. Will take a bit of time to ship so if you want it immediately might want to source it online.
https://magicalproductions.miiduu.com/jpinballs-actuated-chest-mod-bracket-only-jersey-jack-pinball-pirates-of-the-caribbean
#258 1 year ago
Great harryhoudini the part that I’m still confused on - and seems to be lightly documented and no stl file for is the trunk bracket not the servo mount. Do you have that file?
#259 1 year ago
No file has been made yet. It was a manual modification I think pinballj made and I'm waiting on that as well. I don't know if he sent me one, so either I'll get designs from him or fab one up myself. I am talking with a local metal place to produce them once I get the actual design. I can sketch it up in some program if a drawing doesn't exist, just need measurements.
Edit - I'm dumb. pinballj is sending me the top bracket as well. I'll draw it up and post for anyone who wants it and I'll get the fab shop to quote. I have another piece to produce for a different mod so maybe it will be cost effective. I can probably add it in as an option to the 3D bracket alone so you can get both pieces and just pickup the other parts. In the kit I'm including everything you need to install, including all wiring harnesses, etc. Plug and play.
#260 1 year ago
Awesome harryhoudini I’m the meantime I ordered a replacement trunk lid bracket and going to bend mine and test then possibly see if I can make a 3D printed version that is strong enough, this would be great also as it reduces a lot of weight
#261 1 year ago
Quoted from Soulrider911:
I was thinking about that as well. If you end up doing that, it might be easier than fab shop doing a small run of metal and we'll print those as well. I worry they are too thin to be viable unless printed in something expensive.
#262 1 year ago
I’m still learning 3D printing but from what I gather the integrity and strength has a lot to do with the orientation of the part on the printing bed. Also the layer height, and infil (the density of the inside the walls) but as I said I’m kinda new to it
#263 1 year ago
Ordered, thank you sir!
#264 1 year ago
Quoted from harryhoudini:
I'm making a bracket/container for the fake arduino board so you can snap it to the bracket in a vented enclosure instead of having to zip-tie it to the block as it is now. If people hang tight for a day or two I should have it tested and I'll post the change.
#265 1 year ago
Quoted from vireland:
Doh... already printing!
#266 1 year ago
Have it cut in clear lexan. Its how my set up is and you can move the chest RGB light board under it too for better effect , two mods one.
And its bulletproof too. And lightweight
#267 1 year ago
Nice. I happen to have lexan here as well. But I'll call a cnc place. Do you have a template?
#268 1 year ago
Ordered, thx for your work.
#269 1 year ago
I made it from a piece of old iron shelf.
No live JJP part was killed for it.
#270 1 year ago
Just flip the original bracket
#271 1 year ago
My 3D Printer is on the way! Pumped I wanted one anyway this just gave me more of an excuse to get one
#272 1 year ago
Ha! Even roughing it out, I spent way more time on this than I should have. This is a rough print. If you go to .15 or .10 it can look much better.
Here's the Nano enclosure. There are two channels (left and right) inside the enclosure, under the board to run the wiring down to the end of the box and out so it has a clean look. This just has the two switch leads attached for the picture.
I have no idea what heat these generate, so I vented the top, just in case.
Then the Nano enclosure snaps into the modified bigger bracket. Since it takes so long to print a full bracket, I only printed the base of that area to test the fit. It just clips in and out. Pretty nice.
Here's the top part with cable management for the leads to the switch and the leads coming up from the servo on the side. I'm pretty sure I'll be cutting the connector off the servo and soldering the control line straight to the Nano and the power leads to the 5V adapter.
#273 1 year ago
Nice!
Do you know if those dimensions work for all "nano" devices or is that only the specific size of an Arduino?
#274 1 year ago
Nice!
I only have the fake Arduino Nano board from Amazon that the OP suggested for this project on the BoM. No idea how it stacks up to other real or fake Nanos. I'm assuming they tried to fake convincingly, including dimensions, but I have no idea.
#275 1 year ago
Ordered. Thank you for all the work.
#276 1 year ago
Cool, thanks. I purchased a bulk of different (pre-soldered) boards so I'll measure and see if we need to modify to fit or if it is universal.
#277 1 year ago
Which boards did you get? By pre-soldered do you mean the pin headers are on the board? That might be a clearance problem. Since there's so few wires to connect, I didn't even put the header pins on the boards I got.
#278 1 year ago
Ah, I thought the headers were in use with the hookup wires. I can exchange them pretty easily.
I think this is the model: amazon.com link »
I believe the supplier also has them in unsoldered.
#279 1 year ago
With just a handful of wires to connect, it's easier just to push the wires though the holes and solder them directly to the board. I'm hoping to have everything wired up with the revised bracket and nano enclosure later tonight to make sure it all comes together cleanly. Then I can worry about installing it to get the chest working.
#280 1 year ago
Think I’m going to fork the OP’s code and add support for toggling and led strip on and off for those of us that have an led strip in the trunk
Also anyone know where he sources the 5v power from? What connection on backbox?
#281 1 year ago
ATX adapter on the computer power supply to tap the 5V without affecting anything else.
#282 1 year ago
I'm printing the revised big bracket now that I've added some cable management to to clean it up. Once I get this all done, I'll post the revised big bracket and the nano box.
What’s this for? Sorry guys, confused
#283 1 year ago
kornfreak28 he is making a bracket to hold the arduino for the chest meck
#284 1 year ago
HAHA... I was planning on doing that. I was actually going to see about doing the lexan trunk lid plate with the strip behind it. I have a RGB strip with a dimmer/levels so I can set brightness and color. But I use 12v power because it's easily accessible under the PF. But, you can also just use a DC buck converter to take the 12v to whatever you want.
And I have a bunch of this stuff in stock if anyone wants to have it shipped with their mod. I'll get it posted to the site.
#285 1 year ago
Production line is ramping up boys! Got the wife on the job!
#286 1 year ago
Production line is ramping up boys! Got the wife on the job![quoted image]
About time we got them to do something useful.
#287 1 year ago
Just because:
#288 1 year ago
Quoted from KornFreak28:
The existing bracket just has a block and a space to zip-tie the Nano to it, which looks...messy. This cleans everything up and puts it in a clip-on block and has hooks to manage the wires so the install will be much cleaner.
#289 1 year ago
I assume it could just be screwed to the block too, no?
#290 1 year ago
If the block size was increased to allow holes. As it is now, the design is very tight. No wasted space. It's only designed to clip in.
#291 1 year ago
Hot glue it is!
#292 1 year ago
Your team hard at work
"Ms Houdini works on the production line here at Magical Pinball Mods.... blah blah instagram post"
#293 1 year ago
Thanks for the explanation! Is this going to be included in HH’s kit? Or is this going to be sold separately?
#294 1 year ago
We've already been printing brackets (I mean geteos has, lol) so they don't have any changes like this in them. I was actually planning on wrapping the nano in shrink wrap tubing and hot gluing or double stick taping it to the bracket. I don't think the cover will be that big of detraction
#295 1 year ago
I'll post the revised parts so you can print it if you want. I want mine to be a very clean install, but I'm pickier than most.
#296 1 year ago
Well, I certainly hope you rounded all the corners and sanded it
#297 1 year ago
Ha! I ALMOST made the corners rounded, but talked myself out of it to concentrate on functionality/accessibility/wire management. Sanding for a utilitarian product is a bridge too far, so I'm not doing that. These improvements are essentially for my own OCD mollification.
#298 1 year ago
You disappoint.
I was actually thinking about painting them.
#299 1 year ago
Hey Harry how many orders have come in so far? Totally understand if you don’t wanna share just curious about demand.
#300 1 year ago
So cool.. will love this as a kit to put on my potc
14,000 (Firm)
Sale Pending!
Houston, TX
14,000 (Firm)
Sale Pending!
Louisville, KY
Pinball Mod Co.
$ 29.95
Pinball Photos LLC
