Quoted from joseph5185:Ah okay.
It’s not “too” excessive?
makes it fun! plundering only happens when u hit map hole, just remember u can only do it when not in multi-ball. think bedlam gives u a 80 percent of getting plundering award.
Quoted from thc666:makes it fun! plundering only happens when u hit map hole, just remember u can only do it when not in multi-ball. think bedlam gives u a 80 percent of getting plundering award.
Wow!
Okay then... =)
Just curious if anyone thread locks (blue) any of their stuff...specifically THIS game.
Specifically I'm thinking about the plunger assembly (don't want to adjust again...) and flipper assemblies to prevent them from coming lose as well.
Quoted from joseph5185:Thanks for the advice. I’ll probably go with the nicer one. It’s in a nice concealed case. Things like that matter to me.
I bought mine for nothing related to pinball. And I've found various uses for it over the years for things around the house etc. They are very handle tools.
Quoted from f3honda4me:I bought mine for nothing related to pinball. And I've found various uses for it over the years for things around the house etc. They are very handle tools.
It seemed like a really fun toy so I went ahead and picked one up as well as a kit for it.
I think it could be wonderful for cleaning and possibly cutting a chain link for a chandelier I'm trying to hang up.
I'll say this. They seem like VERY versatile tools and when I was in Ace hardware last night, I was completely blown away at all the attachments this thing has.
Looking forward to it...
As an fyi to those removing the ship to put cliffys on, there is no reason to loosen or remove the bp ramp. Just remove the three screws holding the vuk, remove the vuk, and there is plenty of clearance to slide the ship back and remove it. The vuk is positively located, where as the ramp is adjustable, introducing unnecessary variables into the reassembly equation. Further, the brackets that the bp ride on are designed so that the bp is to be removed by sliding it toward the back of the machine, not forward toward the ramp.
672332B7-5731-40AF-9408-6049BB976ECB (resized).jpeg6803CA2D-8EEF-4A5F-AEB2-3091992D4666 (resized).jpegB0D1C270-01D0-45F6-808E-D256610C985C (resized).jpegAs an fyi to those removing the ship to put cliffys on, there is no reason to loosen or remove the bp ramp. Just remove the three screws holding the vuk, remove the vuk, and there is plenty of clearance to slide the ship back and remove it. The vuk is positively located, where as the ramp is adjustable, introducing unnecessary variables into the reassembly equation. Further, the brackets that the bp ride on are designed so that the bp is to be removed by sliding it toward the back of the machine, not forward toward the ramp.
[quoted image][quoted image][quoted image]</blockquoteTimely tip for me. Thank you!
Quoted from joseph5185:It seemed like a really fun toy so I went ahead and picked one up as well as a kit for it.
Off the top of my head I've used it to cut bolts/nails, cut chain link for lights, cut/sand small areas of wood for some remodeling, sand down metal parts on pinball machine, sand my son's pinewood derby car, fix door jamb areas, and more I'm sure I'm forgetting.
Quoted from rs812:As an fyi to those removing the ship to put cliffys on, there is no reason to loosen or remove the bp ramp. Just remove the three screws holding the vuk, remove the vuk, and there is plenty of clearance to slide the ship back and remove it. The vuk is positively located, where as the ramp is adjustable, introducing unnecessary variables into the reassembly equation. Further, the brackets that the bp ride on are designed so that the bp is to be removed by sliding it toward the back of the machine, not forward toward the ramp.
Nice, made this a key post, great tip!
Quoted from f3honda4me:Off the top of my head I've used it to cut bolts/nails, cut chain link for lights, cut/sand small areas of wood for some remodeling, sand down metal parts on pinball machine, sand my son's pinewood derby car, fix door jamb areas, and more I'm sure I'm forgetting.
I used it to get a mushroomed shooter rod off a route pin I bought by cutting the mushroomed end off. NEVER imagined it would one day be used for that, but it worked great.
Did you find this out after adjusting/removing the ramp? I'm having a hard time getting it back in place currently. And the vuk is the real pain in the ass, as far as getting in the way of the ship when removing and resetting it.
Quoted from wesman:Did you find this out after adjusting/removing the ramp? I'm having a hard time getting it back in place currently. And the vuk is the real pain in the ass, as far as getting in the way of the ship when removing and resetting it.
No. Looked at the drawings in the manual and saw how the ship was assembled to the playfield. Noticed that the posts the ship ride on pointed toward the back
Here is what a routed game looks like with the original sling posts (first 3 shots). It looks like someone already got the washer idea (doubt this is factory as the others don't have it) in pic 4. Also, looks like JJP designed their lane divider on the right side with a similar "washer" along the bottom design. I'm sure that's just part of the part characteristics (needs something to keep it up on the playfield for the nuts to pull against) but interesting.
Waiting on star posts, probably will do the clear lexan washers for now unless I can find something better.
0423191508 (resized).jpg0423191509 (resized).jpg0423191509a (resized).jpg0423191509b (resized).jpgDoes anyone else have this audio issue? It's mostly identifiable when it starts up. My WOZ makes a loud "pop" kind of sound but nothing like this. I feel like it's indicative of other game audio issues but I haven't paid close enough attention. Ignore the startup delay, I'm pretty sure the Ubuntu startup screen showed up because I interrupted the previous boot.
Left flipper on the BP stopped working today. It flips a few times and then goes dead. Physical linkage seems fine. I'm guessing bad solder joint or broken wire. Guess I'll be removing the ship again, ugh!
As to the post issue, instead of washers that change the height, why not use a hollow punch set to punch out the correct size dots or circles out of Mylar.
https://m.harborfreight.com/9-piece-hollow-punch-set-3838.html
Quoted from rs812:As to the post issue, instead of washers that change the height, why not use a hollow punch set to punch out the correct size dots or circles out of Mylar.
I really can't see how mylar is going to protect anything. I guess maybe it can prevent a chip from starting but unless you're really easy on how much tension you put on those posts they will dig in to the playfield, probably pop the mylar up and won't really have any protection from the tension from the screws. Clear lexan PETG washers are pretty thick, which seems an issue. Might just have to go solid metal washers that are just a bit larger than the star posts.
Quoted from arzoo:Left flipper on the BP stopped working today. It flips a few times and then goes dead. Physical linkage seems fine. I'm guessing bad solder joint or broken wire. Guess I'll be removing the ship again, ugh!
Save yourself some trouble and just remove the rear vuk rather than the BP ramp. Once removed, there is plenty of room to slide the ship back and up. Vuk is positively located with only three screws. Versus the ramp which is a pain to reset and adjust.
Quoted from rs812:Save yourself some trouble and just remove the rear vuk rather than the BP ramp. Once removed, there is plenty of room to slide the ship back and up. Vuk is positively located with only three screws. Versus the ramp which is a pain to reset and adjust.
Great suggestion, thanks!
Help - How do you install the Cliffy at the Mystery hole? Do you need to remove the jet bumper wafer that's half blocking screws? If so, how the heck do you remove the jet bumper components?
Quoted from rj_tenn:Help - How do you install the Cliffy at the Mystery hole? Do you need to remove the jet bumper wafer that's half blocking screws? If so, how the heck do you remove the jet bumper components?
There are some good tutorials with photos on removing tortuga tom. Search for him in the club thread.
Nice find! I had wondered, after loosening it, if the VUK was the main culprit, and how difficult that would be to tend to.
Are all of those screws above the playfield?
Quoted from harryhoudini:I really can't see how mylar is going to protect anything. I guess maybe it can prevent a chip from starting but unless you're really easy on how much tension you put on those posts they will dig in to the playfield, probably pop the mylar up and won't really have any protection from the tension from the screws. Clear lexan PETG washers are pretty thick, which seems an issue. Might just have to go solid metal washers that are just a bit larger than the star posts.
Actual mylar (not hobby store cling) will protect the playfield fine and likely do less potential damage than a washer or post because the thickness of the mylar will absorb the torque and pressure of the post. All the washers are doing is spreading the torque over a wider surface area and changing the height of the sling rubber. These fragile playfield finishes are a drag. The better they look, the more fragile they are. Bring back diamondplate and just give everyone a respirator.
Check the index at post 1. Same process for fixing a loose or mis-aligned deflector:
Quoted from PinMonk:Actual mylar (not hobby store cling) will protect the playfield fine and likely do less potential damage than a washer or post because the thickness of the mylar will absorb the torque and pressure of the post. All the washers are doing is spreading the torque over a wider surface area and changing the height of the sling rubber. These fragile playfield finishes are a drag. The better they look, the more fragile they are. Bring back diamondplate and just give everyone a respirator.
Would be really interesting if you, too, have a loose roll pin that’s apart of the flipper assembly.
I had the EXACT same issue. I have received replacements from JJP, but haven’t yet committed the time to fix and test.
Ok... I'll trust those who sound like they have more experience than me. I have Marco mylar (and mylar direct from JJP for my WOZ) that I can try out.
Quoted from Av8:This should work. I put sling mylar in my shooter lane also.
Sling mylar?
Quoted from wesman:Nice find! I had wondered, after loosening it, if the VUK was the main culprit, and how difficult that would be to tend to.
Yep! All above playfield. Take those three out and VUK lifts right off. I suggest you get a magnetic extension nutdriver to make your life easier when doing this. Some of the screws are buried pretty deep.
https://www.menards.com/main/tools-hardware/power-tool-accessories/drive-bits-accessories/performax-reg-6-magnetic-nut-driver/c045671/p-1444444262480-c-10156.htm?tid=-7500025011283730123&ipos=7
There are two male pins on brackets, one mounted on the pf on a tall standoff and one on the backboard; and two female brackets on the bottom of the bp with oilite bushings.
How do you use this? Is there an extra tool involved?
By the way, for removing the hex key behind the Black Pearl, this set works fantastically! I think the 1/8" is the correct one.
https://m.harborfreight.com/10-Pc-SAE-T-Handle-Hex-Key-Set-69369.html
Quoted from wesman:How do you use this? Is there an extra tool involved?
The punches are hollow on the cutting end. The hollow end’s edges are sharpened for cutting. I have a set that i use for punching holes in gasket material, cloth, leather, etc. I would use a piece of wood under the material being punched to keep from dulling the punch. You hit the solid end of the punch with a hammer, lightly. The slot in the side of the punch is so you can remove the punched out material from the punch itself. In this instance, you would actually be using the punched out material under the pf post.
Quoted from rs812:The punches are hollow on the cutting end. The hollow end’s edges are sharpened for cutting. I have a set that i use for punching holes in gasket material, cloth, leather, etc. I would use a piece of wood under the material being punched to keep from dulling the punch. You hit the solid end of the punch with a hammer.
Wow!
There’s just so much stuff out there...
Quoted from rs812:The punches are hollow on the cutting end. The hollow end’s edges are sharpened for cutting. I have a set that i use for punching holes in gasket material, cloth, leather, etc. I would use a piece of wood under the material being punched to keep from dulling the punch. You hit the solid end of the punch with a hammer, lightly. The slot in the side of the punch is so you can remove the punched out material from the punch itself. In this instance, you would actually be using the punched out material under the pf post.
Interesting. So you're suggesting using the mylar under the post or around it?
Quoted from wesman:Interesting. So you're suggesting using the mylar under the post or around it?
Under I believe...
I’m going to punch mylar circles out that are slightly larger than the post diameter and use these under the posts. I will probably just use an awl to poke a hole for the post screw once the mylar circles are stuck down on the pf.
Quoted from joseph5185:Sling mylar?
The sling mylar is the half moon shaped mylars that are shipped in the coinbox. Here is where they would be optionally installed by the slingshots, numbers 0 and 1. The rest of the mylars shown are factory installed.
Quoted from rs812:The sling mylar is the half moon shaped mylars that are in the coinbox. Here is where they would be optionally installed by the slingshots, numbers 0 and 1. The rest of the mylars shown are factory installed.
Is there a reason....not to install those sling mylars?
If you do those washer posts, please share photos to show us how they turned out!
Quoted from rs812:The sling mylar is the half moon shaped mylars that are shipped in the coinbox. Here is where they would be optionally installed by the slingshots, numbers 0 and 1. The rest of the mylars shown are factory installed.
Ah, I thought those pieces were for the BP. Haha
Here it turns out these Mylar pieces have names.
Haha
Quoted from wesman:Is there a reason....not to install those sling mylars?
I can’t think of a good reason not too. I will definitely share pics!
Quoted from rs812:The other little square mylars shipped in the coinbox go under the lockdown bar to keep it from scratching the powdercoat on the siderails. Numbers 6 below.[quoted image]
That I knew, but I’m taking it a step further and felting that entire area (though I did use those squares for that exact purpose).
PROBLEM: Sling thin posts or even replacement star posts are digging into the clear on the playfield (sometimes chipping it).
EDIT: Yelobird has posted a much better and more comprehensive repair/protection procedure here: https://pinside.com/pinball/forum/topic/diy-playfield-post-repair-and-chip-proofing-how-to-all-brands
SOLUTION: Remove post, install thin washer or 1.125" mylar disc. Reinstall post, gently tighten, do not torque.
Remove sling nuts using 11/32 socket.
Remove post with 5/16" deep socket. Breathe deeply and often when you see the deep marks in the clear already where the post was. It will all be okay.
Wipe area with 90% rubbing alcohol on microfiber cloth to clean well. Make sure area is dry before proceeding.
Install mylar disc or THIN clear or steel washer. Reinstall post, tightening GENTLY. Reinstall sling plastic and nut.
Here's 1.25" mylar disc (too large, I've dialed mine back to 1.125") installed with off-angle light - almost invisible
Quoted from PinMonk:PROBLEM: Sling posts (and others) are digging into the clear on the playfield (sometimes chipping it).
SOLUTION: Remove post, install thin washer or 1.125" mylar. Reinstall post, gently tighten, do not torque.
Here's the same disc lit:
Nice work! Man those gouges are horrible.
Quoted from harryhoudini:Nice work! Man those gouges are horrible.
That looks fantastic!
Did you use a punch hole set or something to get that precise diameter or?
So that I'm clear (no pun intended), the game does not have star posts by default, right? My game doesn't appear to.
I'm considering green star posts since CE. Thoughts? Or should I just do clear since it will better match the sling rubber?
Quoted from joseph5185:So that I'm clear (no pun intended), the game does not have star posts by default, right? My game doesn't appear to.
Green or blue would look good, I think. I ALMOST did blue, and may still.
This page was printed from https://pinside.com/pinball/forum/topic/jjpirates-of-the-caribbean-troubleshooting-tips-issues/page/7 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
