Quoted from Tigetoo:
Ok looking for some help? Detailed picture of the black pearl underneath wiring. Have agree broken wires. 2 slack on the left/center and looks to go to the left flipper switch. But the one I need help on is the green wire that is broke off. Posting pics here Mabey’s someone cane get me to solution faster.
Also bracket looks to be missing screw. Most concerning is I lost the left targets and left load cannon switch?
Thanks in advance.[quoted image][quoted image][quoted image]
Sounds like the switches out on yours are #9, 10, and 12. See page C152 in the manual where Column 2 shows the switches connected by the green brown wire. They are all connected together by segments of the green/brown wire that broke on yours. So if the wire breaks off a switch that is early in that chain, then all three targets will be out.
This same problem has happened to mine and many other's machines. If you key word search "green brown" in the main club thread or this thread you'll see a lot of results for this issue. It's a straightforward fix if you're able to pull the Black Pearl off and re-solder the green brown wire to the target it broke off from. I'd guess that when you pull the Black Pearl off you'll be able to see where the green wire broke off one of those switches.
