Quoted from Yelobird:
Hey #Volunteerpin just wanted to let you know your motor relay board arrived on Friday. Well I have some good news and some Not so good news. Took my game down and tested both the relay firing as well as the motor operation and the board is perfectly fine. The bad news is you need to keep looking for your issue. But again, at least your not SOL waiting for the relay boards to come back in! I will wrap it back up and ship it back to you tomorrow. Sorry was hoping this was the issue for you or at least try to fix it but it appears the issue is still at your end. I still say Double Triple check the fuses. That is the Same thing that happened on mine and it oddly ended up being a fuse I assumed was fine. Good luck to you!
Well, that is good to know. So, checking continuity of wire between the relay board wires and J109. Here are my results:
YEL-BLU: continuous
YEL-VIO: continuous
YEL power continuous: but this was odd maybe? when I had the meter probe in the YEL at the molex which connects to the motor relay board and checked continuity with all the pins at J109, it WAS CONTINUOUS with pins 1-3 (YEL power, YEL-BLK and YEL-BRN) but not with any of the other pins. I would have thought it would only be continuous with itself at pin 1. Could this finding have anything to do with my issue?
I'm not great with some of this electrical stuff. Here is a snip from the manual showing J109 on the the I/O board:
Also, I had checked fuses F714 and F709 and both were fine. Makes sense that they are as my spinning barrel, spinning pirate, all 3 ramp leds and spotlights are working which are all controlled by J109.
Any additional direction and thoughts are great appreciated.
