Quoted from bbulkley:
I have my first questions after unboxing my new POTC.
The unpacking instructions say to remove any foam behind the playfield. I didn't have any white foam blocks, just this black block that's screwed in place.
Literally the first link in the first post of this thread covers this.
The instructions say when converting from 220 I have to change the pins. I got those out no problem, but there's also a note that the power supply should have a sliding switch on the external case. I assume that's referencing the PC power supply pictured, but I don't see any slider (sorry for the bad picture, but it's just a Corsair PC power supply).
It seems that Corsair ATX power supplies are auto-switching, but you definitely want to run that by JJP or Corsair before plugging in with confidence.
Lastly, I found a few loose bits in the bottom. Two locking nuts, one thumb screw, and one plastic screw cover. Any ideas?[quoted image][quoted image][quoted image]
Thumbscrew goes to the coin door. There should be two (one top, one bottom) on each coin chute at the very back.
Black piece looks like something that goes on the back of the pearl, maybe behind the backboard?
Nuts could be literally anything. There are dozens of these on the machine. HOWEVER, maybe you'll get lucky and they are for the dummy plate for the bill acceptor to the right of the coin chutes with the missing thumbscrew. There should be a white spacer and locking nut on each of the 4 posts (two top, two bottom) for the bill acceptor dummy plate.
