Quoted from AFM95:
Besides the well documented clearcoat issues around the slings, what other common problems should buyers be aware of when buying a PoTC?
I might pick up one in the very near future.
Post #1 pretty much covers it.
Quoted from AFM95:
Quoted from vireland:
Thank you. I appreciate the time you put into that list!
Are most of these adjustments? Or part defects?
Quoted from AFM95:
It covers both. Some are common adjustments some are compensating for bad design.
Quoted from dts:
Curious if there is a way to make the flippers behave more like the fliptronic feel of my TZ, which is very crisp and immediate. I've adjusted the strength, it just feels muddy compared to my TZ.
Tighten up the gaps on the flipper switches? That should take care of immediate and might make them feel more crisp to you.
That makes sense, more likely the "feel" of the flipper buttons. I'll adjust them. In fairness, my current TZ is the most responsive Williams I've ever owned, which is probably because Brian Kelly restored it.
Never thought of that. Seems mine has a very slight hesitation or I could be just imagining things. I’ll try that if I find there’s a slight delay
Quoted from 3pinballs:
Although Vireland I can’t seem to locate your post fix on the first page
I don't think there was a specific post with instructions about various ways to fix that issue, just general tips here and there. Some people have had it, I have not.
So I’m starting to experience intermittent stuck flipper on the right side of the BP.
Pressing the coil shaft all the way in with my finger causes some resistance and can stick if push in the full throw. Is lube a bad idea or what would be best route to address?
Quoted from tgrinchy:
Make sure all the hardware holding the flipper mechs in place are tight. I had an upper left sticking flipper, turned out the hex screw holding the coil stop plate in place was loose, causing the plunger to rub the coil sleeve on the return.
I had this exact issue. Loosen the pawl nut on the flipper and correct the vertical position of the flipper such that the coil moves freely, then re tighten.
What everyone said and do Not use lube on flipper mechs!
Lube/Oil/Grease is never a proper solution to fix a pin. Just imagine all the coil dust we clean out of our machines, now add in a substance that attracts dust. Proly just needs an adjustment.
Quoted from GnarLee:
And for the love of anything holy. Never hose anything down in a pin with WD40.
Quoted from LTG:
That's okay for greasing balls for storage though, yes?
Before use I degrease them with naphtha.
FYI if anyone has had an issue with the black pearl not moving consistently - mind was binding against the wire bundle! Had to affix it to the back of the cabinet in place with a zip tie
Quoted from wesman:
As long as you don't spray them in the game. Yes.
Quoted from Lermods:
Quoted from zaphX:
Quoted from Yelobird:
Quoted from LTG:
Wow, thanks everyone - a wealth of great info! I’ll give these a shot when I remove the BP again.
If your more of a see it done kind of person I strongly suggest watching master LTG's flipper setup video. As I suspect your flipper may simply be binding in the nylon guide this may help get you going. FYI your POTC did not come with the tool he mentions but a simple plastic credit card will work just as well. Good Luck.
Two questions I hope can be answered.
I noticed the Star Map pop up post comes up ok, but has become slow and even hesitates half way down before it fully retracts. What should I look for?
Second, and a minor one, I have yet to have any of the patches or pirate hat show up on a picture since the update. Does anyone think adjusting the sensitivity of the camera would give a better chance for it to happen?
Quoted from Heater:
Best I could suggest is make sure the post (#3) is not rubbing and is centered on the hole in the playfield. Its possible your coil sleeve may be gnarled up (#5) but try centering first. As for the pics, sadly I haven't played well enough to warrant a photo capture lately..... Good Luck.
Quoted from Heater:
The pirate hat and patch seems to be reliant on the shape of the face in the picture. I've NEVER got it with my rounder face, but people angular faces and faces with chin down a bit seem to get them more frequently.
Much thanks. I'll check the assembly and see if its moving freely. And then I'll get liposuction done for my face so I can try to get a pirate patch picture
I have a t-shirt with Jermaine’s face from Fotc. The game once put a hat and patch on him. Missed my face altogether. Maybe it’s done on beauty?
I have a more angular face - never seen the hat and patch once. Not sure what I'm doing wrong!
Quoted from Rdoyle1978:
My face looks like this, and haven't seen jack shit yet....
Guess there's something wrong with me.
Chin down a bit?
I finally took my BP off the game to try to fix some of the issues I've been having with one of the Bonus X stand-ups. I thought it was just gaped too far, but upon closer inspection it's just mounted on the mini playfield too close to the rubber, so it will only activate with strong pressure.
I tried loosening and pushing it further to the right, but as soon as I get tighten the screw at all it goes right back; the bracket doesn't really allow for any horizontal adjustment. Not sure what can be done but filling the old screw holes and mounting it again?
I also wanted to ask if both BP flippers were supposed to have the same amount of movement, or if my left flipper's movement is intentionally shorter? bp_flipper (resized).png
The right flipper has a ton more movement in my game, and I can't remember if the left flipper was always this way, or something that has gotten worse over time..
Quoted from Maide:
I also wanted to ask if both BP flippers were supposed to have the same amount of movement, or if my left flipper's movement is intentionally shorter? [quoted image]
Left and right flipper are the same on the BP. I suspect your Left flipper is at the end of travel (the flipper itself) against the rubber on the playfield which is not letting the plunger fully release. Adjust the flipper topside with the pawl nut below and I am betting you will be good.
Quoted from Maide:
On the upper skull switch your best option would be to simply set the contact gap closer so the target throw to activate would be greatly reduced vs trying to move the switch. Good Luck.
I'm afraid that I'd have to make it so sensitive that non-hits would trigger it; as it is, you have to press down the right-side hard to make it trigger. Dang. I'll try contacting JJP and see if they have any ideas.
Thanks, I'll make them the same, just need to figure out how much of a flip that is haha. For the rest of your comment, do you mean the left in my picture (which is the right flipper when not upside-down), or the right in my picture (normally left)? The left in my picture is the flipper that has much greater amount of movement, but maybe it flips too far? The right (in-picture) is the one that flips less.
On you skull switch have you tried loosening the screw and cheating it to the right? Assuming you have. Easiest thing imo would be to pull out the switch and bore out the hole on switch just a hair. This would give you a bit more adjustment.
Quoted from Maide:
I was referring left or right that the flipper bat throw from the Top needed to be adjusted so they don't bottom out before the plunger can fully extend. In your picture (bottom side) the coil plunger is not fully extended meaning that (right or left) flipper is hitting full travel to soon. Hope that makes sense.
Ah ok, that's what I thought originally, which is why I posted here to confirm. I wanted to make sure there wasn't a game-design reason they had a shorter range of movement on the left flipper so you couldn't cradle or something like that. It sounds like this is not the case, and I should fix it to fully extend.
Quoted from Pinballomatic:
BAG board mounted under the playfield controls all of the lighting more or less. There is a mini USB connector on that board which can come loose or get misaligned in its socket. It's the only mini-USB under the field and usually has a factory tie-wrap on it to hold it in place. Examine and re-seat or straighten if needed. The other end of that USB cable plugs into the "bottom" of the motherboard below the metal box behind the monitor (with the security dongle and the VGA and everything else). Unseat and re-seat the USBs there with game power off. Don't move them to other ports, just unplug and replug.
This is an old post, but I wanted to thank you for it. I was having the same issue with my Wonka lighting all of a sudden. Reseating the USB seems to have fixed the issue.
Not finding my issue on here so far.
The chest release isn't working correctly. When I test the coil, it's like it isn't getting enough power. The mech barely moves at all. I've tried the release timing to no avail. When playing the game and the chest is supposed to release, it goes into ball search.
What do I need to do to troubleshoot this?
Quoted from javagrind888:
Bend the little metal that is on the back so it's closer to the metal post on the coil and it can move the bracket easier (at all?) when energized.
That did it! Thanks!
Same issue with the WoZ munchkin hut ball lock arm over time. It only requires a little bend to get it working well. Glad yours is fixed now!
Not sure if this will help anyone more than any other instructions out there. I think I recall someone else doing a video, but here is one on the BP removal that I have used several times.
https://magicalproductions.miiduu.com/black-pearl-removal-instructions
Added 12 months ago:Not sure if this will help anyone more than any other instructions out there. I think I recall someone else doing a video, but here is one on the BP removal that I have used several times.
Jesus! I thought they said it was going to be easy to remove!
It’s hard the first time. Once you do it, it becomes quite simple. I can get the ship removed in under 4 mins
Quoted from Trooper11040:
Including the ramps and the VUK? Seems like a lot.
You can do it without removing the ramp and vuk, it is a bit tight though.
If you have the bit sizes handy and an electric screwdriver it's a 5-10 minute job. I should time it putting it back together but I would bet someone I could do the whole thing in 10 minutes.
PROBLEM: Tortuga saucer sending the ball SDTM
SOLUTION: Most likely the ball deflector/guide at the back of the Tortuga saucer is loose or mis-aligned. Remove Tortuga Tom and loosen the pop bumper to gain access to the two phillips screws for the deflector that's slightly under the pop bumper skirt. Aim the guard a bit to the left. Test and ensure the scoop fires into the middle of the left flipper. Consider blue loctite to make the fix permanent.
Here's how you get the pop bumper apart to gain access to the two screws:
This is the deflector that you may need to tighten and/or adjust the direction it's pointing:
These are the screws you need to tighten once the deflector is where you want it:
There's a single #1 phillips screw each at the front and back of the barrel you need to remove:
Once the barrel is off, you see a mounting plate, but the hex set screw that holds it on is hidden underneath it. Feel for it and use a hex wrench to loosen it, then slide the mounting plate up and off:
This is a better look at the set screw once the plate is off:
There are now two motor screws to remove. READ THE NEXT STEP BEFORE DOING THIS ONE:
Under each screw holding the motor on, there's a nylon spacer. Be careful to hold the spacer as you lift the screw out so you don't lose the spacer in the machine:
Lift the motor up a bit and set it to the side, which will expose the screws for the pop bumper. LOOSEN, DO NOT REMOVE THEM. Once loose, you can raise the skirt in the front where the two screws are for the deflector and tighten/adjust as-needed:
Reverse the process to put it all back together.
anyone having any pics or directions on how to install the Mystery Hole Cliffy. I'm in process of doing it right now and I'm at this spot in my disassembly and don't know what to do...thx.
remove the ball deflector ( aka snubber bracket), clean area with alcohol pad, install cliffy.
You can remove the two screws on the snubber bracket without taking the pop bumper apart like in vireland’s post, but you might mark up / dent the pop bumper skirt a little bit if you do.
